Correcting A Mistake On A Newly Shingled Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-28-2011, 05:40 PM   #1
Correcting a mistake on a newly shingled roof
After a tear off, I re-shingled my roof last week. Today, I discovered to my chagrin and horror that the drip edge on the eave (downside)side of the roof had been installed incorrectly, i.e. on top of rather than below my lower course of felt. What would you do at this point? Nothing versus pulling it off and trying to install it correctly. Can this be reasonably done without tearing up the roof?
Signed,
One step forward, two backward
sfreeland is offline   Reply With Quote
Old 09-28-2011, 05:44 PM   #2
Rewards Points: 150
So long as the shingle hangs over the drip edge like it should you shouldn't have a problem. You will do more damage attempting to fix then it would be worth.
OhioHomeDoctor is offline   Reply With Quote
Old 09-29-2011, 07:16 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
+1
Ideally, water should not be behind the felt regardless. Leave it. You will tear it up getting the drip edge under.
Replacing shingled roof with metal roof myminpins Roofing/Siding 3 06-26-2011 09:43 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
