Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-22-2010, 03:13 PM   #1
Correct Way to Flash a Vent Pipe With Metal Roof?
Any ideas on the right way to do this? I have a standing seam metal roof and a plumbing vent pipe coming out the top of it. I paid someone to flash it right and bought the standard otaey metal tin with the rubber ring in the middle. He used lots of roof cement all over to patch the edges. Is this the right way to do it? Probably not since its leaking less than a year later.
jonathan03 is offline   Reply With Quote
Old 06-22-2010, 04:10 PM   #2
Shut in w/o Home
seeyou's Avatar
This is the type boot commonly used:
http://www.abccatalog.com/view_groups.asp?idgroup=233
Some caulking is necessary, but there should not be roofing cement involved in the installation.
seeyou is offline   Reply With Quote
Old 06-22-2010, 04:48 PM   #3
You can also get a boot similar to the one CU pictured in various colors. They are called Dyna Flash boots and we get ours at Dynamic Fastener (dynamicfastener.com) and they come in 8 different colors in addition to the standard gray.
Luv2Roof is offline   Reply With Quote
The Following User Says Thank You to Luv2Roof For This Useful Post:
seeyou (06-22-2010)
Old 06-22-2010, 04:56 PM   #4
So there is a glob of roof cement all over the place. I guess I need to clean that up before putting on the new boot? Is gasoline the best way to get it off?
Old 06-22-2010, 04:57 PM   #5
Doing This Way Too Long
One word...Dektite
google it
oh, and, get your money back and get someone who knows what they are doing.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
seeyou (06-22-2010)
Metal Roof Estimate supton Off Topic 5 04-17-2010 04:08 PM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
plumbing vent flashing on metal roof??? red86yota Roofing 14 02-09-2009 12:40 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
