Correct Fascia Panel Size - Roofing/Siding - DIY Home Improvement | DIYChatroom
Closed Thread
Old 03-25-2014, 02:11 PM   #1
Rewards Points: 338
Correct fascia panel size
Im trying to figure out whats the correct panel size to buy.. Right now, its 6 inches on the face with the upper and bottom lips being an inch so Im assuming 8 inch panels... Is this correct?? or Do I need smaller because the top will have drip edge put in???
timothy300858 is offline
Old 03-25-2014, 02:18 PM   #2
Rewards Points: 13,740
Got a picture of what you have now?
Most wrapping is done on site and bent with at least a 10' 6" metal brake.
Any store bought stuff is not going to have a bend at the top and will have two ribs in the center to reduce flexing so it may not match what you have now.
joecaption is offline
Old 03-25-2014, 02:22 PM   #3
Rewards Points: 338
That is what I was getting at.. The old stuff on the house either has a "built in" drip edge or it was bend on site... Ive noticed the new stuff is only bent underneath.. Which means the drip edge that I will have put on will do the top.. So my question is... since the face is 6 inches, is that the size I go with?? Will it have the bent edge on it also and leave the face the correct width??
Old 03-25-2014, 02:22 PM   #4
Rewards Points: 338
And its all getting replaced so I wont have to worry about matching anything existing stuff
Old 03-25-2014, 02:38 PM   #5
There is no need for that top bend if there's a drip edge. It slips in under it.
Your fascia board is going to be 5-1/2 not 6" most likely, then the soffit most often is about 1/2.
Posting that picture will be a big help to tell you some other steps and tools your going to need.
The ends of the run need to be bent over leaving a 1/2 bend with a pair of seamers so there's no open gaps where the two pieces over lap.
Old 03-25-2014, 02:46 PM   #6
Rewards Points: 338
So I need to order 6 inch panels then... thanks
Old 03-25-2014, 02:55 PM   #7
Need to see that picture, need on the end where the rake and the fascia meet.
Premade fascia is not going to work out in some cases because of the boxing on the end.
Need someone on site to bend a piece to cover it.
Old 03-25-2014, 03:06 PM   #8
Rewards Points: 338
I don't know how to load a picture on here otherwise I would... But that's okay.. Im gonna go with 6 inch.. Thanks for the help
Old 03-25-2014, 03:08 PM   #9
Rewards Points: 144
Joe is correct.In my area most ar 6" standard facsia that can be bought pre bent at the lumber yard.There are also a lot of houses built in the 80's and 70's that had a 1X2 nailed to the top of the fascia that goes under the drip edge that you can not buy.
Has to be broke so pics would be very helpful.You will also have the return that needs to be broke.If 6" is to wide you can cut off the hem at the top and make it fit but you need to be careful installing it as that hem adds some rigidity.
mako1 is offline
Old 03-25-2014, 03:20 PM   #10
Rewards Points: 338
I don't understand what you want a picture of... Its not taken apart yet... So you would see a finished soffit and fascia... Only thing I know is that I will be replacing some of the wood for the fascia and also sistering new ends on some of the truss ends due to rot... And as far as I saw when I had the roof redone, there wasn't any extra wood added onto the top of the fascia so I think Im good there...
Old 03-25-2014, 04:15 PM   #11
Rewards Points: 144
No more I can help you with.Seems like you know it all.
mako1 is offline
Old 03-25-2014, 04:18 PM   #12
Rewards Points: 338
Totally cool with me.. Have a nice day!!!
Old 03-25-2014, 05:02 PM   #13
Rewards Points: 144
I am a general contractor and have been in the trades for around 40 years.I visit these boards to try and help people out and spend lots of my free time doing it because I enjoy it.I'm here today because I could not do the job because of the weather here and enjoy it.
I don't understand why someone would ask a question on the forum and then disrespect someone with the knowledge to answer their question for asking for a picture?A picture is worth a thousand words .
Good luck to you on your project and I wish you well with it.
mako1 is offline
The Following 3 Users Say Thank You to mako1 For This Useful Post:
47_47 (03-26-2014), BigJim (03-25-2014), kwikfishron (03-25-2014)
Old 03-25-2014, 05:18 PM   #14
Rewards Points: 338
Congrats!!!! You've been in the trades for 40 years.. Makes it necessary to posts comments like your last one I guess... You said you couldn't help me anymore and I said ok.. have a nice day... Why not leave it at that??? I dont understand the reasoning behind it sometimes... But whatever.. I wish you well also... Take care and have a GREAT day lol
Old 03-25-2014, 06:21 PM   #15
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
Tim,
Some people are visual, some folks are able to visualize.
I am probably more the former than the latter. I appreciate pictures as well and it usually helps elicit more feedback is all.
Mako and Joe and all the other guys here might, not saying he was here, be a bit gruff sometimes be we are trying to help homeowners get it done right at the end of the day.
Windows on Wash is offline
Closed Thread
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
Wire size to sub panel zom Electrical 4 06-03-2011 09:46 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Off Peak Panel Size a7ecorsair Electrical 4 09-22-2010 12:56 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
