Corner Of Shingle Broke Off - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2008, 09:34 AM   #1
sweaty
Rewards Points: 276
Corner of Shingle Broke Off
I get up on my roof about once a week with an electric leaf blower to blow off the leaves. I notice that, sometimes, the cord gets caught under a corner of a shingle. The other week, I noticed that one shingle had a corner missing.
Do I need to replace this shingle? I don't want a leak in the house.
Should I use roofing cement or something to glue down all the shingle corners? It's a big area.
sweaty is offline   Reply With Quote
Old 09-09-2008, 10:11 AM   #2
Just be careful with the cord from now on. If you can find the broken off corner, just apply 2-3 small quarter sized dabs of roofing cement from a caulk tube under the broken tab to put it back into position.
It probably will not leak, even if you do not do that, but better safe than sorry.
Ed
Ed the Roofer is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 01:35 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
