Cor A Vent ? Good Ridge Vent? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-30-2012, 03:31 PM   #1
cor a vent ? Good Ridge vent?
Installing Timbertex ridge caps this weekend.
Has anyone installed this product.
http://www.cor-a-vent.com/v400.cfm
I am either going to use this or ridgevent ii that some people have liked. The ridgevent ii looks very thin to me, but I think it rates high with air flow. My local building supply store recommended the cor-a-vent. THANKS
zman22 is offline   Reply With Quote
Old 11-30-2012, 04:55 PM   #2
Solutions (handyman)
Rewards Points: 364
vent
I have used several types of ridge vents and they all seem to do the job. Where I am my concern was whether temperature might be an issue with the material cracking but it all seems to stand up fine. The brand names vary and I would just look for a ridge vent that is easy to install, has some mesh or other anti bug element (to prevent bugs from entering the house) and is flexible. Most major home improvement stores have former roofers on staff so get their suggestions and make a somewhat informed decission. Personally I wouldn't get too hung up on a brand name ... for this product.
Mark Harvey is offline   Reply With Quote
Old 11-30-2012, 05:41 PM   #3
Metal Roofing
Rewards Points: 600
I have some of the thier other venting products and liked them. I would use them again for sure.
AndyWRS is offline   Reply With Quote
Old 11-30-2012, 08:06 PM   #4
dabs of sealant
Thanks for the replies. Since it's getting cold her on Long Island do you recommend adding a couple of dabs of sealant per cap to keep them down. The days of 65 degrees and above weather are gone for at least another 4 months. The Timbertex is pretty thick stuff.
Old 11-30-2012, 08:12 PM   #5
ParagonEx's Avatar
Rewards Points: 150
When we used to install GAF products and the timbertex, we would use 2.75" hand nails along with the snow country. Never had any problems even during winter installations.
ParagonEx is offline   Reply With Quote
Old 12-01-2012, 04:59 PM   #6
Registered User
Rewards Points: 526
http://paragoninspects.com/pdf/vent/...-myth-rose.pdf
Gary
Old 12-01-2012, 05:44 PM   #7
Doing This Way Too Long
Rewards Points: 532
Wind-blown light powder snow will infiltrate cora-vent. I've seen it on several roofs. Crawl up in the attic space and see berms of snow in a nice straight line. It obviously doesn't happen ALL the time. I'm just saying it is possible in just the right conditions. That is why I stopped using it. Strictly ShingleVent II by Airvent for me anymore.
OldNBroken is offline   Reply With Quote
Old 12-03-2012, 02:34 PM   #8
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I've never been a fan of coravent. My personal preference in ridge vent is Air Vent Shingle Vent II. You can also try Cobra II, which is a copy of the Shingle Vent II. Don't mess with the original cobra roll. Never tried the snow country ridge vent.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 12-03-2012, 05:50 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
We use AirVent II as a standard but all the rigid ridge vents are good.
We have used the GAF Snow Country and it is a nice piece as well.
Ridge Vent installation on a hip roof Projectsgalore Roofing/Siding 6 09-05-2012 06:52 PM
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 04:26 AM
Ridge vent leaking? Or what? Whatever1 Roofing/Siding 10 09-25-2008 06:24 PM
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 07:30 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
