Contractor Reccomendation : Install Cricket... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-01-2010, 08:44 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Contractor reccomendation : Install cricket...
Upon getting a bid for the siding repair on this house we're purchasing, one of the contractors (aside from giving us an 83,000 dollar bid for siding) recommends installing a cricket at the butterfly joint in the roofs. (garage roof eave tied into house roof eave to create a covered walkway into the house.
Can someone explain to me what a 'cricket' is and how one would 'install' one and if it is even a DIY project?
Thanks,
-Alan
Journeyman Plumber
Old 03-01-2010, 10:08 PM   #2
Rewards Points: 352
83,000 dollars is a lot of siding, The only cricket I am familiar with in roofing is where the slope of the roof meets an obstruction like a chimney they build a small structure from the chimney to the roof to keep water from getting trapped behind chimney. there may be other kinds of crickets but I am not a roofer or nailbanger
plumberinlaw is offline   Reply With Quote
Old 03-01-2010, 10:14 PM   #3
Chimney cricket:
Old 03-02-2010, 07:57 AM   #4
jlhaslip's Avatar
Rewards Points: 2,820
Sometimes called a 'saddle'.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-02-2010, 09:09 AM   #5
Doing it myself
Alan's Avatar
Basically it's to keep water from sitting on the back side of the chimney then?
They must be custom made then i'm assuming?
Journeyman Plumber
Old 03-02-2010, 10:26 AM   #6
Yes, to keep water, leaves, snow & other debris from building up
This prevents leaks
Each one is is custom made for the chimney - as far as I know
Old 03-02-2010, 01:47 PM   #7
thats a nice cricket- yours dave?
The older I get the better I was
Old 03-02-2010, 02:49 PM   #8
No, not mine - off the web
Old 03-02-2010, 09:08 PM   #9
Doing it myself
Alan's Avatar
My 'butterfly joint' is probably 30' long at least.
I'm assuming something like this will have to be made out of lumber. Is this something a roofer would do, or better to hire a contractor to frame it and then get a roofer to come in after?
Journeyman Plumber
Old 03-04-2010, 07:18 AM   #10
Depending on the skill of the roofer, he may be able to frame it on and do both. However, if it is large, I would hire a carpenter to do the framing and a roofer to do the roofing.
BamBamm5144 is offline   Reply With Quote
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
