Contractor Has Thinner Siding Than Contracted - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-20-2013, 08:11 PM   #1
Question
Contractor has thinner siding than contracted
We contracted for siding that is 044 thickness but I just noticed the siding that was dropped off by the wholesaler is a different name and thickness . The contractor said he will discuss and review the situation on Monday when they resume work. None of the siding has been installed yet, just the insulation. Question: How much of a big deal should I make of this when he offers an explanation. It could be the wholesaler dropped off the wrong order (Alside Coventry was dropped off instead of Alside Odyssey Plus) , or perhaps the contractor was trying to pull a fast one . I suspect he may try to lower the contract price and suggest we use the stuff that was delivered. Should I hold out for the stuff that was specified in the contract? Is the extra thickness worth insisting on and delaying the project ?
obrienaj is offline   Reply With Quote
Old 07-20-2013, 08:42 PM   #2
firehawkmph's Avatar
Rewards Points: 1,826
AJ,
I hang alside siding and normally use the odyssey line. The coventry line is not quite as good. It's a step down. If you contracted for the odyssey siding, have him get the right stuff delivered before they start hanging the other. Could have been an accident, could have been on purpose. At this point, exchanging it would be simple. Might hold up the job for a few days if its not in stock, but in the whole scheme of things, I would wait and get what I wanted.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
AndyGump (07-21-2013), kwikfishron (07-20-2013)
Old 07-20-2013, 08:44 PM   #3
Rewards Points: 6,652
Someone pulled the wrong order. I would not let the contractor hang anything, until you get the correct order on the truck, and delivered to your property, and the wrong order taken back to the warehouse.
Old 07-20-2013, 08:44 PM   #4
Thanks very much, we will do as you suggest.
Andy
Old 07-20-2013, 08:45 PM   #5
Rewards Points: 13,300
Not that big a deal but I personally would make them take it back and replace it with the right one if that's what's in your contract.
The thicker it is the flatter it lays, less chance of damage, less brittle when it's cold.
Old 07-20-2013, 09:03 PM   #6
Rewards Points: 582
get what you contracted for ...that is why we use contracts...no guess work here only facts...ben sr
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
AndyGump (07-21-2013), gregzoll (07-20-2013), kwikfishron (07-20-2013)
Old 07-21-2013, 10:35 AM   #7
Home Remodeler
Rewards Points: 164
What is 044 thickness ?
mikey48 is offline   Reply With Quote
Old 07-21-2013, 10:49 AM   #8
Rewards Points: 228
Originally Posted by mikey48 View Post
what is 044 thickness ?
.044"
Fix'n it is offline   Reply With Quote
Old 07-21-2013, 10:59 AM   #9
Home Remodeler
Rewards Points: 164
That is pretty thin. 1/16 inch = .062
Old 07-21-2013, 01:47 PM   #10
Jim got me, I moved the decimal point from the hundreth to the tenth. So yes, pretty min. stuff. Only good for the hood.
Old 07-21-2013, 02:01 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Originally Posted by gregzoll View Post
.044 is thicker than 1/16th. 0.44 is 11/25. Is is a little thinner than 1/2". See http://math2.org/math/general/arithmetic/fradec.htm
Divide .0625 into the number one, it will = 16
divide .044 into the number 1, it will = 22.727 times, making 1/16 larger than .044.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-21-2013, 02:18 PM   #12
You got me. I moved the decimal point from the hundreth to the tenth position. Easy to do, and I bow to you Jim.
Old 07-21-2013, 02:33 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I thought that was what happened, I have done that also.
Jim
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
paint thinner stains on vinyl siding. patt Painting 6 06-04-2007 05:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
