Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-13-2012, 06:26 AM   #1
consequences if patio awning has a 10 degree fall instead of 5 degree
I am going to install a stratco outback awning over my patio area. The cover will be attached to two walls to the house, the size is 6m x 3m . The manual says that the angle should not be more then 5 degree. What is the reason for that? What would happen if I install it at and angle of 10 degree?
LabRatte is offline   Reply With Quote
Old 08-13-2012, 11:10 AM   #2
Architectural Designer
AGWhitehouse's Avatar
with what little info you gave my assumption is the 5 degree is the minimum pitch to shed water. 10 degree will only help to shed the water faster.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-13-2012, 11:12 AM   #3
Most people here will not even know what a stratco outback awning is.
Can you post a picture or at least a web site?
Old 08-13-2012, 04:56 PM   #4
http://stratco.com.au/products/veran..._flat/flat.asp
Old 08-13-2012, 05:39 PM   #5
? Why would you not be asking the manufacturer this question?
Where do you live, I could be wrong but that sysyem sure looks pretty flimsy.
AGWhitehouse (08-14-2012)
Patio awning design check RodBarnes Building & Construction 4 07-28-2012 06:51 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
