Connecting Two Roofs - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-23-2008, 08:51 AM   #1
Whatamess
Question
Connecting two roofs
Hi All,
I am trying to help a friend with a problem of joining two roofs. There is new construction that has a hip roof to join an existing oval roof. The oval is approx. 10 feet in diameter and 20 feet long. The problem is how to connect the two and carry the rain away. There is an existing 4" gutter on the dome but I don't think that will handle the added surface area. The new roof will have tile installed.
Any suggestions would be appreciated.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-23-2008, 07:37 PM   #2
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
You're probably not going to be able to do this yoruself unless you have extensive metal working experience. My only advice is to call an experienced metalworker who does custom guttering and or metal roofing systems.
The way I'd approach it is to have the carpenters frame a cricket or saddle to direct the water flow then I'd line that saddle with all grace premium ice shield then install a flat locked soldered seam roofing system in galvanized or if the bidget allows with copper.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Connecting two roofs TazinCR Building & Construction 2 07-23-2008 09:19 AM
Connecting air cleaner to return air elbow jdelisle HVAC 1 07-10-2008 05:44 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
connecting ballcock supply line? Yeti Plumbing 3 10-23-2007 12:11 PM
