Condition Of Decking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-14-2010, 04:20 AM   #1
condition of decking
Inspected my attic today and notice blackish stains around the roofing nails, slight streak about 1.5 to 2 inches on each side of nail and about 1/4 to 1/2" thick. This is consistent around all nails, but the rest of the decking looks healthy just the slight blackening around nails. Its dark at the center but then is a lighter and fainter black as it moves out. Is this normal for 10 year old roof decking?
matrixman is offline   Reply With Quote
Old 09-14-2010, 05:58 AM   #2
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Sounds like a ventilation problem. More specifically a condensation issue. This could be from winter only or more likely year round.
Do any of your kitchen and or bathroom vents dump into the attic? Does your insulation block the intake of your soffit/overhang vents? Do you even have soffit intake ventilation? What type and how much exhaust ventilation do you have? All these things can be related to your problem.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 09-14-2010, 02:45 PM   #3
Rewards Points: 956
oh yea thats what i am afraid when they tear up the decking to my roof
federer is offline   Reply With Quote
Old 09-14-2010, 03:39 PM   #4
But if it was a general ventilation/condensation problem, wouldn't I see discoloring in other places as well? Why only on each nail? Does condensation on roof tend to infiltrate a bit via the surrounding nail and would this be normal or a result of improper installation?
They lead up into the attic and thru the roof. I have soffit intakes, I assume since I have a soffit and I do see in the attic these styrofoam or plastic blue soffit guards/baffle.
Old 09-14-2010, 05:41 PM   #5
Doing This Way Too Long
Rewards Points: 532
The reason you are seeing it on the nails is not necessarily caused by a ventilation issue. Research "thermal bridging" and you will see why nails through wood are conducting heat, causing the condensation to concentrate on the nails, thereby causing moisture to slowly wick out into your decking from the nails.
OldNBroken is offline   Reply With Quote
Old 09-17-2010, 10:40 PM   #6
Thanks kinda figured it was odd and only by the nails. However, I did notice 2 to 3 rafters beams in corners that have sap dots all over them. I believe I read that this is an indication of a very hot attic where it literally cooks the sap out of the wood. So I may have a ventilation problem during summer but in winter the condensation is probably not as much a problem. Thinking of putting up some solar fans instead of the small ridge vent at top which does not seem to be working well. Not sure though if they will be powerful enough to suck out the air and not sure what manufacturers make some good ones.
Old 09-17-2010, 11:29 PM   #7
jlhaslip's Avatar
Rewards Points: 2,188
Guaranteed that if you have a ventilation issue one season, it doesn't go away during the other season.
Read up on the requirements for roof ventilation and ensure that the soffit vents are not getting blocked.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 09-18-2010, 01:35 AM   #8
Rewards Points: 956
i need to post more pics on here and have you guys laugh at me
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 04:55 AM
Decking Michael Avram Building & Construction 2 05-26-2008 07:24 PM
Plastic decking? kcrossley2 Building & Construction 4 10-08-2007 10:59 AM
