Condensation Inside Ceiling Of Cathedral Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-23-2011, 11:56 AM   #1
Question
Condensation inside ceiling of cathedral ceiling
We have a large living room (18x25) with a cathedral ceiling. Lately, we have gotten brown stained drips along the slanted ceiling from the center beam (fake) down, and the beam is getting wet and warped. We are in the middle of a very hot and humid summer (110 heat index) so I figured it was related to condensation between hot humid attic air and cooled indoor air. I've read about venting for cathedral ceilings and think a ridge vent added to our current attic vents might help. What's unusual about our house is that the cathedral ceiling runs perpendicular to the angle of the roof. Any special considerations for this situation? Will the ridge vent likely fix the problem?
HandyDaddy is offline   Reply With Quote
Old 07-23-2011, 04:07 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Sounds to me like there is insufficient insulation or venting or both. Would you explain this for us? Or pictures.
"What's unusual about our house is that the cathedral ceiling runs perpendicular to the angle of the roof."
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-23-2011, 05:58 PM   #3
kwikfishron's Avatar
Rewards Points: 1,008
You could also have a leak.
I think it’s time to poke your head up in the attic and take a look.
As mentioned, post some pictures.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
BigJim (07-23-2011)
Old 07-24-2011, 09:05 AM   #4
Clarification--Cathedral Ceiling Condensation
The line of the apex of the roof on our ranch style house runs end to end, as you would expect. But the line of the apex of the cathedral ceiling runs from the front of the house to the back. The ceiling area in the photo is at the back, just in front of a brick fireplace. I'm pretty sure that the brown streaks are stain being leeched from the beam. The other photo shows center of room where beams meet, and shows how the beam that is moist is warping. There is a gap between the beam and the actual ceiling at the end, and the air coming through the gap is very hot. Hope this clarifies my original post. Thanks for any suggestions.
Condensation inside ceiling of cathedral ceiling-warped-beam-center-cathedral-ceiling.jpg   Condensation inside ceiling of cathedral ceiling-4th-july-cake-007.jpg
Old 07-24-2011, 09:22 AM   #5
Do you have access to the space above that?
Old 07-24-2011, 02:17 PM   #6
Response-condensation on cathedral ceiling
There is an attic, very difficult to get to, so I haven't yet, but know I will have to get up there once the weather cools a little.
Tags
attic ventilation , cathedral ceiling , condensation , ridge vent , ventilation
Cathedral ceiling - metal ties cboulard Building & Construction 1 07-05-2011 07:27 AM
Need for venting in a Cathedral ceiling Hensel Roofing/Siding 6 12-04-2009 12:00 PM
Cathedral Ceiling Sweats Dan H Roofing/Siding 14 02-22-2007 11:40 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
