Condensation On Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-15-2012, 04:40 PM   #1
Question
Condensation on ceiling
Hello, I need help figuring out this puzzle. I have a four season porch that we made into a dining room when we moved into our house. The wall was removed and there was an addition added to one side of this room. I has a vaulted ceiling, the room and the ceiling are cedar with a 12" X 12" beam at the top. Every year when the weather gets warm, condensation starts to drip from the ceiling, the house smells like hot wet air. I have to turn on the ceiling fan and leave it on for the rest of the summer.
We live in Minnesota, the room has 1 1\2 outer walls. It is off the kitchen and then there is a pocket door to the mother-in-law apartment.
Can anyone tell me what we have to do to fix this problem?
CooksIn is offline   Reply With Quote
Old 05-15-2012, 04:59 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Tear off the roof or tear down the drywall.
What is the roof type (vented or hot style)?
Old 05-15-2012, 05:24 PM   #3
Rewards Points: 268
If the wall is 1 1/2 the normal thickness, make sure there is insulation and vapor barrier. Also make sure there is some ventilation.
packer_rich is offline   Reply With Quote
Old 05-16-2012, 08:03 AM   #4
Not sure what a "hot" roof is, there are vents in the soffit.
Walls are normal 6" walls. Insulation could be some of the problem but would that be in the summer? Winter months it is cooler but no condensation problems on the windows or the ceiling. This happenns only in the summer when it is hot outside.
Old 05-16-2012, 08:53 AM   #5
Rewards Points: 898
Think of the warm moist air outside and not the cold roof rafter because you are conditioning the space.
Warm moist + cold = condensation.
Take some pictures but the roof system you are describing rarely works well when it is put together as most folks do.
Old 05-16-2012, 12:16 PM   #6
Remodeling Contractor
For a quick solution keep a fan exhausting the moist air out of the room. Keep the humidity under 45% and you will be fine.
Old 05-16-2012, 01:32 PM   #7
Rewards Points: 898
+1
Good suggestion Bob.
This will help during the winter months but it will not affect the condensation inside the roof assembly.
Old 05-16-2012, 02:11 PM   #8
Originally Posted by Windows on Wash View Post
+1
It should only occur in the roof assembly if the ambiant indoor air contains enough moisture and heat to drive (by diffusion) into the assembly and then condense on the surface against the cold roof. In the summer moisture would only be present if the roof is leaking.
Old 05-16-2012, 02:41 PM   #9
Rewards Points: 898
Diffusion and what is more problematic is bulk air transfer and the moisture it carries.
I have seen cold side (i.e. back side of the drywall in the summer) of a roof sweat when the outdoor humidity is high and the space is conditioned and kept cold enough.
This is why most vaulted ceiling assemblies with vented interstitial rafter bays are terrible performers. There ability to resist dew point stinks on both ends of the season.
Old 05-16-2012, 04:43 PM   #10
Registered User
Rewards Points: 4,924
I'm with Bob on this, warm moist air is condensing ON the plastic vapor barrier under the cedar ceiling finish material. Or on the cedar with lack of insulation and well vented rafter bays.
You have an excessive moisture problem. What material is the floor? Is there a crawl-space? Is it vented? Is the dirt covered with a min. 6mil vapor barrier? Is there a v.b. on the ceiling? Are the rafters vented? Is it a slab-on-grade? Is there a v.b. under the slab? Is the backyard always wet- natural springs, valley, etc.? Are you running the AC? Need more info.....
Gary
Old 05-16-2012, 06:40 PM   #11
Just failed at trying to load some pictures of the room. I did post them on my FB page if you want to go and look at them.
http://www.facebook.com/media/set/?s...1&l=b6c3a17826
There is not a slab under the room it is dirt, last fall we closed it with plywood & siding and put insulation on the inside wall. No vapor barrier was laid.
We live on a river, the river is about 300 yards from the back yard. There is some wet land on the property.
The ceiling sweats when the AC is NOT on. If I turn on the AC and the fan it will stay dry. When we first moved in I had no idea what was going on, for that matter still don't. I brought in a ladder and went up to see if I could dry off the ceiling and see if there was a leak or what....At about 8 feet, the air started getting hot, hot and wet and I noticed that the whole ceiling was wet along with the beam. Right now the house smells like hot atic when you come in. When I turn on the AC in about an hour the smell is gone. There is only one register for that room but the register for the oringinal kitchen wall is still there too.
Thanks for all your help on this.
Judy
Old 05-17-2012, 08:14 AM   #12
Rewards Points: 898
Gary
+1
That is the most likely and especially given the poster's update. I was just pointing out I have seen both.
Good info though and Bob's original suggestion of the dehumidifier is the quickest way from point A to point B but it is not a long term solution.
Old 05-18-2012, 11:58 PM   #13
Registered User
Sounds like the dirt floor is giving excess moisture which rises from the "stack effect'; http://www.wag-aic.org/1999/WAG_99_baker.pdf
First off, cover the dirt, tape or seal it to the wall mudsill. http://dirt-crawl-spaces.com/crawlspace-dirt.html
If the area is not heated/cooled, ventilate it. Your framing will grow mold and rot if left alone. Is the furnace/HVAC down there?
This may work; http://www.buildingscience.com/docum...n-crawlspaces/
You still need to ventilate (outside air) or move conditioned air down there. Closed crawl: http://www.buildingscience.com/docum...ance-and-codes
Gary
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 12:36 PM
Condensation on ceiling near water heater. EkS Plumbing 5 10-12-2010 11:48 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Condensation on cathedral ceiling barbaraizac Roofing/Siding 46 09-26-2009 11:48 PM
