Condensation In Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-02-2008, 11:59 AM   #1
Hi all at DIY. I am a new forum member and this is my first post.
I had a new roof (shingles) put on my house. The old shingles were removed. The chimeney was also removed to the roof line and boarded over. (We had an energy efficient furnace put in a few years previously.)
Since the new roof, we have had condensation in the attic in the winter months. I can feel and see moisture on the roof boards and frost will form on the roofing nails that were driven through the roof.
I have had additional insulation installed and I installed additional vents under the sofit.
I am convinced that problem is with the chimeney. The top of the chimeney was not sealed off, simply removed to the roof line. The chimeney was wrapped with insulation.
You thoughts and feedback is greatly appreciated. Thanks.
george@DIY is offline   Reply With Quote
Old 02-02-2008, 12:21 PM   #2
concretemasonry's Avatar
Rewards Points: 2,654
did you make sure your chutes between the rafters are completely open to take advantage of the new vents?
You could be losing heat and moisture up the old chimney if it was not sealed off. You should definitelt seal the old chimney top after you make sure the chimney does not have anything else coming into it.
concretemasonry is offline   Reply With Quote
Old 02-02-2008, 01:04 PM   #3
Explain in detail how much exhaust ventilation and intake ventilation you have now.
Saying that you added some intake vents does not say anything much to me.
What kind of and how many of each types of vents?
Do you have competing exhaust vents?
Ridge vents, mushroom vents, powered attic ventilator, or gable vents?
Also, the bottom of the chimney in the basement is probably allowing the moisture from the lower area to shoot up the chimney and then get ewxpelled into the attic copartment.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-03-2008, 10:36 PM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
did you use unfaced insulation,putting faced insulation on top of faced can creaste a condensation problem,You should also check to see that your boiler,and dryer exhaust pipes are not routed to that chimney
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
attic condensation darren Roofing/Siding 11 01-24-2006 10:27 PM
Attic Condensation billinak HVAC 4 11-09-2005 06:18 PM
