Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-24-2011, 12:07 AM   #1
Old Hand
Concrete Tiles
4 years ago we had a new roof installed; the roofer recommended light concrete tiles. They look great and we've had no issues with leaks. We do have one major problem.
No one can go up on the roof without breaking tiles when they are walked upon. We just had the house tented for termites and it took me hours to replace the tiles; not the workmen's fault.
The only solution I have for this issue would be to take two 3 x 3 foot pieces of plywood to lay across tiles to distribute the weight (and put some type of rubber or soft grip underneath). It still does not seem to be a good idea to be carrying flat pieces of board up on the roof where a gust of wind could hit.
Any great ideas? Thanks,
iliketowork is offline   Reply With Quote
Old 09-24-2011, 07:05 AM   #2
Residential Roofer
Slyfox's Avatar
Concrete Tiles
Every step you take should be with your foot firmly on the spot where the courses of tile over lap one another.
If your still breaking tiles while walking on them properly than you have defective material issue.
Of course this is coming from a roofer with limited experience in tile roofs, but I have walked hundreds with multiple different types of tile and did so with out damaging them, minus a few mis-steps here and there.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 09-24-2011, 09:57 AM   #3
Old Hand
Concrete Tiles
Thanks. This is understood. The issue is that if you take a minor mis-step the tile breaks. The pest control team knew how to walk on the roof but it was just not possible to walk the course overlap while moving the tent. I did recieve one good possibility of using the new type of backerboard for bathrooms, light weight and maybe thick enough to spread the weight. Thanks for the reply.
Old 09-25-2011, 01:38 AM   #4
Exterior Construction
Windows on Wash's Avatar
Concrete Tiles
If they are breaking when being walked on properly, there are faulty materials and spreading out the load on a larger surface may or may not change that.
The Following User Says Thank You to Windows on Wash For This Useful Post:
iliketowork (09-25-2011)
Tags
concrete tiles, roof
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Broken Concrete Tiles Cultcab Roofing 11 01-23-2011 10:10 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
