Concrete Slurry Ceiling Insulation? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2010, 07:14 AM   #1
concrete slurry ceiling insulation?
Hi,
I desperately need some advice on a shed/music space currently going up in the backyard...The structure is made of weatherboard and plasterboard/drywall panels with a thin inner layer of polystyrene covered in a polystyrene bead and concrete slurry mix as a type of insulation. The reason for the slurry is its soundproofing capabilities.
The ceiling of this 3x3 metre space is made up of 6 panels; each 1 by 1.5 mtres long. Each of these has an extra joist down its centre. In addition, a beam runs along the length of the space, supporting each of these ceiling panels. My worry is each of these panels is also filled with a concrete slurry/poly bead mix-the weight is aprox 11k per square metre. Is this too heavy?
Has anyone ever heard of this kind of insulation for a ceiling? My understanding is that rockwool is around 6 k per square metre in weight.
Any help would be greatly appreciated..
mwools is offline   Reply With Quote
Old 04-02-2010, 08:10 AM   #2
Where are you located ?
Old 04-02-2010, 06:18 PM   #3
Location added to profile..
Hi,
I'm located in Melbourne, Australia...
Cheers
Old 04-02-2010, 09:17 PM   #4
Registered User
Rewards Points: 526
"Join Date: Apr 2010 Location: Melbourne, Australia
Posts: 2"
You keep doing that, Dave, lol. I'm not familiar with that construction, ask your local building department. Or go to a sound control forum? Doesn't the contractor know? Is the slurry on a wire lath?
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
mwools (04-03-2010)
Old 04-02-2010, 09:39 PM   #5
Posts: 2"
Be safe, Gary
Uh..yeah...and after I ask they update their profile
Old 04-03-2010, 04:14 AM   #6
Thanks for the reply Gary. The cement isn't on a wire lathe and unfortunately theres no contractor as it's a small backyard job being built by a friend.
I know it's an unusual insulation material for the ceiling..think I'll call the drywall manufacturer to find out what the max recommended load is..
Thanks again
Halina
Old 04-03-2010, 04:39 PM   #7
Registered User
Rewards Points: 526
I may be wrong... 2.2# for 5/8" drywall? http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, Gary
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 03:33 PM
Installing insulation in basement ceiling epeterson777 Building & Construction 2 02-22-2009 10:37 AM
Newbie Insulation Question: Cathedral Ceiling Battman328 Building & Construction 5 01-24-2008 05:37 PM
insulation b/ween concrete and gravel in live-in basement amakarevic Building & Construction 6 08-15-2007 12:02 PM
