Concrete roof on house... problems!!
Sounds like OSB adhered to the concrete deck ,Wherever you exposed this you should cover it,and if it`s not leaking ,you can leave the snow,Is there a way to add extra insulation beneath the roof,if you can stop the escaping house heat from the roof,you won`t have any more ice up there
"If it`s worth doing,It`s worth doing right!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
