Concrete Roof Anchors - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-28-2011, 11:50 AM   #1
Concrete roof anchors
I need to replace my sloping built up roof on a commercial building (3,000 ft2)
Options are rubber, tpo, torch down.
the roofer who is pushing torchdown is saying that I will have problems with iso anchors backing out of my cement roof if I use rubber or TPO. Has anyone ever heard/experienced this as a problem? I am keeping the building so I want long
lasting roof without issues.
Thanks,
Will67
will67 is offline   Reply With Quote
Old 06-28-2011, 12:46 PM   #2
Too Short? Cut it Again!
This might be worth a call to the manufacturer of the rubber membrane roof you had in mind? Doesn't sound right to me but if there is a potential problem they should have a suggested fix for it? You are going to get so many more miles out of a membrane roof than a torch down unless you dance on it with golf cleats or something.
The Following User Says Thank You to user1007 For This Useful Post:
will67 (06-28-2011)
Old 06-28-2011, 04:33 PM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks,
Will67
The insulation or recovery board would be anchored the same way under torch down. Might be a problem, but the same problem would exist for all mentioned coverings.
seeyou is offline   Reply With Quote
Old 06-29-2011, 10:58 AM   #4
Thanks for the input. With the torchdown we wouldn't ues a recovery board. Just clean off the BUR and put down the new roof.
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
New outlet in concrete roof? alternative? vtanuku Electrical 2 02-19-2009 02:54 PM
