Composition Shingle Styles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 03:29 PM   #1
My home's roof has cement tiles that look like clay tiles and are pretty heavy. The roof is framed in an open style sheathing with 1 x 4's and no felt paper below. I'd like to have the cement tiles removed from my home and wonder if there is a style of asphalt composition shingle that looks similar to tile or slate?
Can someone provide manufacturer websites so I can browse them?
RM575 is offline   Reply With Quote
Old 08-08-2012, 10:10 AM   #2
Rewards Points: 850
cant think of one. i do know they have some pretty heavy, thick, composition shingles but you pay a arm and a leg for them.
hotrod351 is offline   Reply With Quote
Old 08-08-2012, 12:39 PM   #3
Well, it might be worth it. Because, my roof leaks when there is a wind driven rain. Also, I plan to do a small addition and I've learned that the manufacturer of this tile is either out of business or no longer manufactures this tile.
I wouldn't need something that looks exactly like tile, just something that is not a stark contrast so my home won't look out of place in the neighborhood.
Thanks for your reply.
Old 08-08-2012, 07:51 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Perfect design for 10"-12" wide slate which will be lighter, and if installed with 3"-4" headlap will lay directly on ths slats and windblown rain shouldn't be an issue. Depends on pitch. Steeper is better.
tinner666 is offline   Reply With Quote
Old 08-08-2012, 07:57 PM   #5
Rewards Points: 12,876
If you Google "rubber slate shingles" lot of pictures and web sites come up showing the look and products avalible.
There not as easy to install as reguler shingles so I might suggest you go on the companys website that makes them. Most will have certified roofers that have been to one of there classes.
Any real roofing supply can also give you some leads. (not some box store!)
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 10:05 AM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 11:09 AM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 01:40 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
