Commercial Roof And Drain Gutter Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 08:00 PM   #1
Commercial roof and drain gutter repair
I have a commercial building with comp. shingles shedding onto a sheet metal gutter on both sides of the 4/12 pitch roof. The metal gutter has corroded through the years due to water ponding segments. I have patched the metal gaps with mastic from time to time. Now, the corrosion is rusting through the metal gutter in pinpoint openings too small to detect or see with normal visual inspections causing leakage into the shop space underneath. I am considering hot mopping the metal valley gutter drain but am concerned that the added asphalt layering will thwart a positive water flow, exacerbate water ponding sections, and stifle drainage down to the end downspouts. Any ideas? Your input is much appreciated! Thanks.
kingchuck is offline   Reply With Quote
Old 04-23-2011, 09:23 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I'd use a product such as Geocel 2315 brushable sealant. Remove all the loose tar and coat any suspect areas. It's a rust inhibitor and is pretty UV resistant.
seeyou is offline   Reply With Quote
installing a roof drain -BUR drbracken Roofing/Siding 6 12-02-2010 11:33 AM
French Drain to Drain Roof DIYTKINNEY Landscaping & Lawn Care 2 11-08-2010 05:53 PM
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 11:58 AM
Gutter connected to FRENCH DRAIN gioman Landscaping & Lawn Care 14 09-28-2010 06:36 AM
Flat Roof Ice Dam help alladin15 Roofing/Siding 3 03-15-2010 11:12 AM
