Cold Flat Roof Construction - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-19-2011, 11:36 AM   #1
Question
Cold flat roof construction
I have a cold flat roof over my kitchen extension and the water supply pipes are in the ceiling. The pipes freeze in the winter despite me leaving heaters on all night in there.
I understand that this form of construction is now illegal in Scotland. can i easily convert it to warm roof construction?
Ding1e is offline   Reply With Quote
Old 08-19-2011, 12:54 PM   #2
Low Slope Roofing
Rewards Points: 114
depending on slope and type of roof you have now (I asume torchdown) you can just add extruded EPS insulation on top of the existing roofing and add ballast rock on top of that. The down side, this makes repairs very hard. But its the cheapest option outside of reroofing.
1985gt is offline   Reply With Quote
Old 08-19-2011, 01:24 PM   #3
Rewards Points: 252
Welcome, I was in Scotland a couple months ago, excellent country!
Is there any insulation in the ceiling? How much space is there between the roof deck and ceiling? Is there any ventilation along the walls of this space?
Adding EPS (styrofoam) and ballast rock is a good suggestion, but you would have to check to ensure your structure could support all that extra weight (doubtful). You might be able to get away with adding insulation and a new membrane to existing, but you would have to insulate the wall space between the deck and ceiling as well (and close off the ventilation). This may be possible from the exterior, but would require new cladding.
If there is room to work, the cheapest way would be to build an insulated box on the sides and top of the water pipes so bring them into the 'heated space'. Moving the pipes may be cheaper (box them in along the top of a wall)
shazapple is offline   Reply With Quote
Old 08-19-2011, 01:40 PM   #4
Low Slope Roofing
Rewards Points: 114
On an install like this you wouldnt need as much as you think. Normal ballast roofs specs are 10 pounds per sq foot. That is to hold the whole system down, EPDM and insulation. plus the wind factor. You just need to hold the insulation down. you could use half or less. Yes it is always good to double check the structure, and you have to figure in snow load and existing roof conditions. There are a number of house around here (US) that have ballasted roofs on them. I wouldnt think building codes would be that much different in Scotland but I wouldnt know for sure.
Now that you mentioned the "heat Box" we did something very similar to that in our new shop when we were building it, we had a pipe that would keep freezing in the walk way connection. So we built a box wraped the water line in heat tape, insulated the line with fiberglass and then insulated the box. Havent had a problem since.
Old 08-19-2011, 04:09 PM   #5
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
it seems strange to me that a cold deck design would be made illegal. It seems more plausible that the outlawing of running the water pipes essentially outside would be more fitting.
Keep in mind any retrofit may be a complete waste of money if there is some kind of ventilation system, which usuallya ccompanys cold deck designs. Any of this ventilation would need to be closed off, which could in and of it's self cause a whole other pile of problems.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Tags
cold roof , flat roof conversion , ventilated flat roof.
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 11:58 AM
Flat roof insulating danomac Roofing/Siding 4 09-04-2010 10:43 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 04:31 PM
