Cold Drafts From Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-02-2011, 10:28 PM   #1
Cold drafts from roof
Ok, I had a new roof put on my house in early June (I live in Michigan). So for there have been no problems at all. There have been no leaks, there were no huge heat drafts, no issues what so ever. But, over the last 3 weeks the cold drafts have been almost unbearable at some points. This was the only home repair that was done on the house all summer.
I was wondering if somebody could point out what could possibly be wrong or any other ideas about why my house is so cold already this fall.
Thanks, for any light you can shed
p.s. if this is in the wrong forum, can you please move it to the correct one.
shaftman11 is offline   Reply With Quote
Old 12-03-2011, 12:22 AM   #2
Doing This Way Too Long
Rewards Points: 532
Unless they were in your attic messing with insulation I can't think of any reason a new roof would have any bearing on draftiness. Do you know how good the insulation in the attic is? Michigan's a sucky place for this problem this time of year.
Attic insulation is one of the cheapest and highest ROI a homeowner can do to their home.
OldNBroken is offline   Reply With Quote
Old 12-03-2011, 07:38 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I wonder if the house was poorly insulated/sealed with an un-vented attic and they added venting.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Gary in WA (12-03-2011)
Old 12-03-2011, 10:41 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
This would be my first guess right here.
If they opening up the ridge or soffits and the wind wash is stripping the R-Value now.
Post up some pictures of the exterior of the home (eaves, ridge, etc) as well as some interior pictures of the attic.
Old 12-03-2011, 10:46 AM   #5
Rewards Points: 12,808
In your area it's suggested to have at lease R-50 which is 12" of insulation in the attic.
If you walk up into the attic and it's warmer then the outside temperature then there's not enough insulation. An unfinished attic needs to be about the same temperture as the outside air.
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 01:10 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
