Cobra® Ridge Runner Exhaust Vent For Roof Ridge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2012, 07:10 PM   #1
Hello. First time poster here. I have a 3 story townhouse in NH. I was doing some attic insulation work over the summer, and noticed that the "weather filter" which is a fiberglass mesh type of product under the ridge vent is plugged with dust, insulation, etc.
Does it make sense to just rip this filter out? I need to go through the attic because the condo association will NOT allow me to do any work on the roof side.
Should I replace the filter with another one? How is this done? Thanks!
rocko62580 is offline   Reply With Quote
Old 08-26-2012, 11:29 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 850
Just vacuum it out.
Make sure it isn't over-nailed and obstructing the flow of air in the attic.
Old 08-27-2012, 04:35 PM   #3
Rewards Points: 43
I noticed that filter in the Shingle Vent II at Lowe's on the weekend and thought the same thing, just a matter of time till that filter is clogged!
The roofer I am considering uses the Venturi-Vent, which doesnt have the filter. They both however have that lip on the outside, with holes to let the water out. I guess it's just a matter of time till those holes clog up too with seedlings? That would require getting on the roof.
How is the longevity of the plastic ridge vents? I see some have a 30 yr warrantee. Have they even been around long enough to track a 20 or 30 yr cycle?
Al
AlleyG is offline   Reply With Quote
Old 08-27-2012, 04:37 PM   #4
Rewards Points: 850
The rigid ridge vents are far more proven than the Cobra vent fiber mesh.
Just vacuum out the filter as the debris that was accumulated was done when the insulation was blown in.
Old 08-27-2012, 04:42 PM   #5
the Musigician
DangerMouse's Avatar
What about those that lost access to their attic as soon as the insulation was blown in? Sort of hard to go up and vacuum, so how could they clean the vent from the outside?
DM
Old 08-27-2012, 04:52 PM   #6
Haverhill Trade 1965
It depends which side has the dust. If it covers the inside vacuum from the inside or use a vacuum with an exhaust, (leaf blower on low), to blow it off from the outside. If the outside is clogged , reverse the process.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
bbo (08-27-2012)
Old 08-27-2012, 06:24 PM   #7
Rewards Points: 850
DM
I would make sure your insulation company doesn't clog it up to start with.
We normally have some compressed air or a broom with us.
+1
Solid advice.
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 04:47 PM
Add Ridge Vent? AlleyG Roofing/Siding 17 08-28-2012 01:05 AM
Wrong roof vent for bathroom exhaust? vanishingson Roofing/Siding 18 04-04-2011 07:25 AM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 05:59 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
