Coating Torch Down Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-13-2007, 02:59 PM   #1
Unhappy
coating torch down roof
A year ago there was a small leak in my 12 year old torch down roof. This is the roof on my 14 X 14 screened porch. It might have been from a tree limb falling on it. Anyhow - small leak.
I had the best roofer in my area repair it. He fiberglass patched two leaks and then coated the whole roof with a black substance. I don't know what it was - but it's peeling off already. One year later. Oh boy.
Before I call and have him look at it, I wanted to know what you DO coat these roofs with - if at all. I need some ammunition.
He charged me almost as much as the roof originally cost 12 years ago, but that's my dumbness of being in a hurry, liking the guy and wanting it done before winter. I paid him $525.
Even at 73 I went up a ladder and looked. I remember the original roofer called it a Brie roof. I had always thought it was metal, but it seems to bend a little.
Betsy G is offline   Reply With Quote
Old 10-13-2007, 03:46 PM   #2
He probab;y used an oil based emulsion to coat the "Brai" by US Intec, modified bitumen membrane.
Now that the emulsion or similar coating is in place, it won't be a good candidate for any type of coating repair, which in my opinion, is a jack-leg hack job to begin with.
Even with Chicago area rates, it would not have cost much more to re-roof the entire roof, if there are no special hard to do details involved.
Ed
Ed the Roofer is offline   Reply With Quote
Old 10-13-2007, 11:20 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
usually a smooth surface "brai" roof would be coated w/a fibered aluminum roof coating which would reflect the heat and seal the roof laps and surface,depending on what was done ,you can probably still do this,can you post pictures of the roof in it`s present state??
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 10-14-2007, 11:36 AM   #4
It would be hard to take photos right now. I think the torch down was still o.k. except for a small leak the guy fiberglassed - but the black stuff he then coated the roof with is chipping and peeling. I don't see how he can recoat with aluminum without sanding the black stuff off.
I wonder if he could shingle over it all.
I have tons of shingles left from the rest of the house's roof.
The porch roof 9 feet 8 inches long
There is an 18 inch slope.
The main roof comes down and spills onto this screened porch.
There is flashing under the main roof shingles and the Brei.
Since I paid this guy $550 to coat 10 feet by 14 feet including a small repair, I wonder what he would knock off a bid to shingle this roof.
I think it's a case of this supposedly reliable roofer taking advantage of a 73 year old widow since my house is in a good neighborhood and makes me look rich. But bottom line, the older part of the house was built in 1916 and isn't as great as it looks. And I'm far from rich.
I just believed he was putting on the correct coating as he's been around a while. I should have gotten bids and looked up what you coat these roofs myself but I guess I fell off the turnip truck that day.
If my neighbor comes back and puts the ladder up against the porch again I'll take photos.
Old 10-14-2007, 11:40 AM   #5
you may be able to "carefully" powerwash the roof and then put the alum coating,It doesn`t sound like the roof pitch(angle)is appropriate for shingles,I`d probably call someone else
Leaking roof -recommend a roof coating? Faust Roofing/Siding 5 07-12-2007 10:09 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 05:08 AM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 05:39 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 07:29 AM
