Closed Valley Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-24-2011, 04:17 PM   #1
Closed valley leak
Couple pics of a valley on my roof that is leaking down into the soffit. One of the pics attempts to show how there is a very tiny hole at base of valley. Is this not correct? How should it have been done?
I've been told that this hole is source of leak and entire valley must be reconstructed. Thing is, valley on other side is done same way but no leaks there.
Just seeing what others thoughts are.
Atskodinski is offline   Reply With Quote
Old 03-24-2011, 07:02 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Let's see.
Cut side isn't 2" out from center.
No pipe collar.
Nice hole in the end of the valley where that shingle is cut.
I seriously doubt the cut side has the shingle tops cut off either.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
MJW (03-25-2011)
Old 03-24-2011, 07:04 PM   #3
Pro Slate Roofer
tinner666's Avatar
I forgot to add, No flashing on/under/into that short sretch of fascia either.
I'll bet the other side comes to grief too if the same person did it.
Old 03-24-2011, 07:28 PM   #4
Originally Posted by tinner666
Let's see.
No pipe collar.
Pipe collar is getting corrected.
How do I go about correcting that hole? And checking the shingle top issue?
Old 03-24-2011, 07:31 PM   #5
Which side are you referring to? Or is that the hole into the roof at the corner there?
Would a potential solution be to remove a few rows of shingles so I can install flashing into that hole, the reshingle?
Other side is the same, but no leaks
Old 03-24-2011, 08:18 PM   #6
Pro Slate Roofer
tinner666's Avatar
Pull 3-4 shingles on the l. side. Install flashing under the shingles/behind the fascia all the way to the valley apex.
Remove and replace the cut shingle. It goes under the ones from the r. No cutting.
Start at the top of the valley and each shingle must be lifted ant it's top cut paralell with the rafter,ie straight up.
Browse my site. See the pages about chimney and step flashing, the valley pages, the power vent install, and any other that might be pertinent.
Look closely! If any of the shingles from the right have a butt-joint within 6" of the valley, it needs to be corrected!
Old 03-24-2011, 09:02 PM   #7
Rewards Points: 1,088
Should have put ice and water shield on the valley.
What is up with that crack on the lower shingle?
Where is the boot on the pipe collar?
handy man88 is offline   Reply With Quote
Old 03-24-2011, 10:01 PM   #8
RFN-4A-LVN
Roofmaster417's Avatar
My recommendation is to have the valley pulled and reinstalled and here is why,
Serious rookie errors:
1.)Pipe flashing.
2.)Improper lace of a closed valley. #1 IMO possible cause.
3.)Possibility of no step flashing in the wall area under the eave.
4.) Like Tinner said valley cut is more than the required 2" out. (Not likely IMO to be the cause of your leak but shows rookie roofing.
5.) Like Tinner also stated points left in the valley.(Not likely IMO to be the cause of your leak but shows rookie roofing).
6.) The drip edges is squared up possible cutting into the shingles dormer side.
IMO it comes down to piece of mind,meaning,knowing the problem is fixed or wondering if you found the cause.
I would hire a professional contractor you trust to have the roof inspected.
Roofmaster417 is offline   Reply With Quote
Old 03-25-2011, 06:01 AM   #9
Pro Slate Roofer
tinner666's Avatar
[quote=handy man88;616412]Should have put ice and water shield on the valley.
quote]
I pull apart several every year will storm shield in them. If the roof installation is worng, it won't help one iota.
On the same token, I've removed many a roof that lived a full life and didn't even have felt in the valley, nor had they leaked when the roof installation was correct.
The Following 2 Users Say Thank You to tinner666 For This Useful Post:
MJW (03-25-2011), seeyou (03-25-2011)
Old 03-25-2011, 11:54 AM   #10
Thx all. Turning this one over to the pros. I don't have enough experience with roofing to try and monkey around with a complicated valley. Better to let a pro do it and know it's fixed.
Old 03-25-2011, 04:23 PM   #11
[quote=tinner666;616573]
quote]
I can't argue with that, but it's better to have ice and water shield than not.
Many people have leaks and just don't know about it b/c they never venture into the attic. This is especially the case for those with cellulose insulation which would absorb any water that gets through.
Old 04-09-2011, 07:02 PM   #12
first coarse in the valley needs to be weaved also no boot for the pipe
freddieshingler is offline   Reply With Quote
Old 04-14-2011, 06:29 PM   #13
OMG I sure hope you don't live where it snows or rains too hard because your in for some major leaks... Redo that whole valley
Don Smith is offline   Reply With Quote
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 10:21 PM
open vs closed valley KarlJay Roofing/Siding 1 09-19-2010 07:58 AM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
1000 bucks to fix the valley on my roof, is this ok? astronomer25 Roofing/Siding 3 09-14-2008 08:36 PM
