Originally Posted by ben5048
I am attempting to insulate a catherdral ceiling.
You're going to have to use the CC foam, or fir out your rafters (12" ?) so you can fit the recommended R value of fiberglass, plus a two inch air space under the decking, plus baffles to protect that air flow, plus continuous soffit intake vents, and continuous ridge vent. In other words, forget about fiberglass.
While I know that closed cell insulation has a higher R value, the space being insulated has very limited space between the roof deck and the sheetrock, thereby forcing me to deal with the problem of heat transference.
The temp differential is what's forcing you to deal with the heat transference. I.e. it's cold out and you want to stay warm. You're dealing with that by insulating.
What you should worry about is
vapor transference. The air space above fiberglass insulation is to carry any conditioned air vapor (moisture) that leaks from inside the house out the roof vents. CC foam is perfect for cathedral ceilings because it becomes an air barrier at one inch, and a vapor barrier at two inches. Any vapor that would normally go out the ceiling and into the attic is blocked by the foam, so that warm air can't condensate on the underside of the decking.
I've read that if I don't have enough thickness for the closed cell insulation, the added gain by the higher R value with closed cell will be lost due to this principle. If this is true, what is the minimum thickness i need? I have 5 inches to work with.
CC foam is R 6-7 per inch. Five inches would be about %75 of the recommended R value for attics in my region.
I'm not sure what you've been reading, but not the right things. Building Science is the best source of info on what their name suggests. Here's what they have to say about unvented attics:
http://www.buildingscience.com/docum...r-all-climates
