Clear Or Clear-grey Suntuf Roof On Patio?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-12-2014, 11:39 PM   #1
Rewards Points: 8
Clear or clear-grey Suntuf roof on Patio??
I would love some advice on balancing light and heat with the roof on a patio. We are building a wood deck and half of it is covered. We are not sure if we should use Suntuf Clear or Solar Grey(35% light transmission, less heat transmission). The roof beams and purlins have been engineered for Suntuf with our snow load. We have very rainy grey falls, snowy winters and really hot summers. The open walls of the deck face south and west. There will be grey metal siding on the unfinished wall in the photo. I think the clear panels would be great for 10 months of the year, but I'm worried that they will create a bit of a greenhouse hot space in summer. We plan to mount shade sails on the underside of the roof for those hot months, but I'm still worried that with the clear, it will be too hot. But I'm concerned that the grey will feel too dark on the rainy cloudy days and block too much light from entering the windows. I would love any input you have from your experience. Thanks!
alibaba12 is offline   Reply With Quote
Old 10-13-2014, 07:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Where is the home located? The passive solar question is a function of heating vs. cooling degree days.
Old 10-13-2014, 08:51 AM   #3
Rewards Points: 8
Revelstoke, British Columbia, Canada
450m elevation.
Old 10-13-2014, 08:53 AM   #4
Go clear. It will help much more than it will hurt. In the summer months when it's warm install a ceiling fan and circulate the air.
Old 10-13-2014, 08:57 AM   #5
Rewards Points: 8
Really? So will the clear magnify the heat from the sun on hot days? (ie. will it be hotter under the roof than on the open deck beside it?) I'm just worried that we are creating a greenhouse, and we really need some shade...
Old 10-13-2014, 09:09 AM   #6
Rewards Points: 8
We also are planning to put either the clear or the grey over our carport on the front (south side of the house as well but opens to the east at the other end, instead of the west). I just don't want to step outside into a 'greenhouse' feel on either side, and I don't want the car to be sitting in a space that is hotter than the outside space around it. I just don't know how to determine the effects of clear vs grey in this space. Any ideas?
Old 03-31-2015, 11:30 AM   #7
Rewards Points: 1,066
did you ever install your Suntuf panels? If so, how it is going? if not, what did you do?
tstex is offline   Reply With Quote
New Patio Roof Construction ryanb4614 Building & Construction 7 07-16-2012 05:53 AM
replacing a patio roof - i can't diy eibyer Roofing/Siding 5 05-23-2012 02:13 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Adding a roof over a patio etully24 Roofing/Siding 5 06-08-2010 07:58 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
