-   -   Circular Cut - Fiber cement siding (http://www.diychatroom.com/f9/circular-cut-fiber-cement-siding-181897/)
DukeLewis87 06-15-2013 06:54 PM
Hello
Power Meter on side of house with elbow 90 degress into the siding 7" above starter strip
Powers been shutdown and I have it pulled away from the wall. Its about a 3" Round cut ill have to make somehow.
How do you cut siding or design trim around the elbow that goes into the side.
Router?
I also thought about boxing around the entire thing but that would look kind of stupid with a dark siding with white outlined trim.
kwikfishron 06-15-2013 07:10 PM
199 Attachment(s)
Jig saw, hole saw, personally I wouldn't let any of my router bits near that stuff.
DimeBag1976 06-15-2013 07:15 PM
There is also an electric siding shear saw that is made specifically for "Hardie" boards and will cut a radius. I know Makita makes one and I am sure there are other manufacturers have their own version.
DukeLewis87 06-15-2013 08:54 PM
Hrmmm
jagans 06-15-2013 10:23 PM
Multi tool with a half moon carbide chip blade should work
one cut 06-15-2013 11:54 PM
All of these suggestions will work. But... The siding shear will not give you a clean cut, they are more for straight lines mostly. The hole saw is expensive and will be ruined. The multi tool with carbide blade would be hard to get a clean line as well. Use a jig saw and consider the blade done for after a few cuts, they are cheap.
Windows on Wash 06-16-2013 10:09 AM
I would go with the oscillating saw (i.e. multi tool that jagans mentioned).
It is easier to controls and be sure to keep the dust down with either a vacuum or spritz it with water.
joecaption 06-16-2013 10:43 AM
I use a split flush mount siding block.
http://www.kaycan.com/us/?page_id=2683
I lay it on a piece of plywood and stand on it, line the pilot bit with the center of the opening and use a hole saw to make the round hole.
