Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-05-2012, 11:57 AM   #1
Chimney Water Leaks in Basement
Hi: I have a repetitive issue with rain water leaking from the base of my chimney in the basement.
It happens in heavy rains.. I do have a cap on the top. Any ideas on what to do so I don't get this water? I have had tuck-pointing done and also have flashing around the chimney where it meets the roof. I get enough that it will flow to my basement drain.
Am I missing anything?
Tx,
Tom
roztom is offline   Reply With Quote
Old 07-05-2012, 12:01 PM   #2
Post a picture of that chimmney.
Just because there's a cap and flashing it does not mean it was done right to prevent the leaking.
Old 07-05-2012, 12:18 PM   #3
I can't get up on roof.. so where would I look for this.. Is it a flashing, tuck-pointing? Any other possibilities? Tx Tom
Old 07-05-2012, 12:25 PM   #4
Cracked crown, rusted out cap, no cricket on the high side of the chimmney, poorly done flashing, not sealed around the flue. Could be any of these and a few more. No way to tell without being there.
Old 07-05-2012, 12:41 PM   #5
What kind of contractor should I get for this? Tx..
Old 07-05-2012, 01:08 PM   #6
If it were me, I'd start with a full service roofer.
Evstarr is offline   Reply With Quote
Old 07-05-2012, 09:24 PM   #7
Metal Roofing
"base of the chimney in the basement"
Foundation is also a possibility. How about a pic from outside showing us the chimney and from the inside showing us the water damage / staining.
Also, is the ceiling or wall wet or damaged ? we need more info to provide you with the proper direction.
AndyWRS is offline   Reply With Quote
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
Water in Basement pawprts04 Building & Construction 2 07-19-2011 11:28 PM
Water in Basement RMCarner Remodeling 10 03-13-2011 10:13 AM
basement wall waterproofing Jenbarkel Building & Construction 9 08-30-2010 06:37 PM
Advice for a novice: Mold and water damage in basement xoxJanette General Discussion 1 12-29-2009 07:54 AM
