Chimney Pot Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-21-2013, 06:57 AM   #1
Chimney Pot Vents
Hello: can anyone reccomend a device that will both prevent most rain water from falling into the chimney pot and will allow a solid fuel stove or open fire to function efficiently?
Have tried one that resembled a chinese hat with a mesh below but it caused the fire to emit smoke into the room.
And while you're there, these clay chimney inserts or elephant's feet as sometimes called. If they are not sealed into the pot then what prevents all the water that falls on the 'foot' being drawn by capillary action straight down the chimney?
PedrX is offline   Reply With Quote
Old 02-21-2013, 07:07 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Chimneys by definition have updraft which prevent water from going down them. Check it for proper draft. Any cap that slows any water from getting in will take care of what the draft doesn't evaporate.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
PedrX (02-22-2013)
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
