Chimney Pointing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-08-2009, 05:23 PM   #1
Chimney pointing
Is there a Quickcrete product for chimney pointing? If not, what do people use?
Thank you in advance.
Lugnut is offline   Reply With Quote
Old 11-08-2009, 06:00 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Maybe use their High Strength stuff. Just guessing, of course.
tinner666 is offline   Reply With Quote
Old 11-08-2009, 06:31 PM   #3
Rewards Points: 582
I've always mixed my own mortar for re pointing, using one of the NHBC recommended mixes.
1/0.5/4.5 OPC/lime/sand, or 1/3.5 OPC/sand + added plasticiser or 1/3 masonry cement/sand. These are good for harder bricks.
These mixes have always done well in our climate, but yours may vary if it's a lot different.
Generally speaking strong cement mixes are not recommended for old softer brickwork, but are sometimes used in very exposed conditons.
On really old decorative stacks a hydraulic lime mix would be better.
There isn't really one mix that applies to all jobs, it's a question of picking the right one for a particular stack.
stuart45 is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
