Chimney Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-31-2010, 09:01 AM   #1
Rewards Points: 123
chimney leak
I had a new roof put on 10 years ago and the contractor just tarred around the outside of the chimney. I think there is flashing under the shingles but just tar at the bottom of the chimney. The tar is now peeling away from the chimney so there is a gap between the chimney and the shingles.
Can I just re-tar the gap? If not does anybody know the right way to fix this problem?
jerry1967 is offline   Reply With Quote
Old 07-31-2010, 09:54 AM   #2
kwikfishron's Avatar
Rewards Points: 782
Tar’s just a band aid.
This should give you an idea of what needs to be done.
kwikfishron is online now   Reply With Quote
Old 08-01-2010, 11:38 AM   #3
Roofing Cement without any fabric reinforcement wil Always crack. Usually, whichever surface that is more pliable that it is ttached to will be stuck sufficiently enough to the hardened plastic roofing cement so that the expansion and contraction of the roofing cement will also start to tear that product, which in your case would be the roofing shingles.
This has a strong probability of creating a large enough tear through the shingles to eventually allow water to enter.
It "May" not happen that way for some time, but it "Probably" eventually will.
The tar and affected shigles will need to be neatly removed and cleaned up completely with new shingles installed for the pieces that were removed and then all new base, step, apron, counter and rear pan flashings will need to be fabricated and installed.
Ed
Ed the Roofer is offline   Reply With Quote
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 06:52 PM
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 08:46 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
