Chimney Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-11-2011, 11:20 PM   #1
Chimney Leak
I have a home built in 1930. It has a chimney running thru the center of the house 1 1/2 stories thru the roof to the basement where the furnace is. On the second floor the chimney is leaking thru the plaster which is around the ceiling and it is causing bubbles to form thru the paint and a little mold going on. I had the chimney repaired 2 years ago with new flashing because it was also leaking in the same areas. This time due to a huge amount of rain in April it started leaking again. What could be the problem now and how can it me fixed?
Barbara Henze is offline   Reply With Quote
Old 06-12-2011, 05:33 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Just because the flashing was replaced doesn't mean it was replaced properly. The water could also be entering through the crown of the chimney. Some pictures would help us diagnose.
seeyou is offline   Reply With Quote
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 06:52 PM
Persistent Leak - Chimney or Roof? CMoorhead Roofing/Siding 33 03-07-2011 08:46 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
