Chimney Insulation. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-13-2012, 09:53 AM   #1
Chimney insulation.
What heatresistent item/glue/sealer can I use to seal a metal chimney to a metal flange to keep it waterproof?
Chris Delport is offline   Reply With Quote
Old 06-13-2012, 10:18 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Assuming you mean the storm cap that slides down the pipe to the pipe collar on the roof, use Permanent Gutter sealer. Heat resistant is not necessary since all chimne pipes are 2-3 layers. ( If not, yu have the wrong pipe and need to replace it ASAP!)
tinner666 is offline   Reply With Quote
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 11:36 PM
Capping my chimney sbmfj General DIY Discussions 9 10-29-2011 11:45 AM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
