Chimney Flue Hole - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-05-2007, 07:40 AM   #1
Question
Chimney Flue Hole
We are preparing to put a Class A Chimney Flue through our metal roof (4/12 pitch) which also has OSB sheathing on 16 inch center scissor trusses. We are considering triple wall which we understand can be installed 2 inches from combustibles. We'll need to put the pipe through the small attic area (24 inches high). Has anyone lined that flue space with Durock? Or how have you addressed the issue?
Any suggestions on cutting the hole in the roof? Round? Square? What tool?
And what is the best high temperature flashing to use?
Thanks!
Liz
leezarrd is offline   Reply With Quote
Old 11-07-2007, 06:36 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That's fine.
No need to worry about that space.
Round, about 2" larger than the pipe.
The metal collar is fire-proof.
tinner666 is offline   Reply With Quote
Old 11-08-2007, 09:22 AM   #3
Thanks, Albert!
Old 11-10-2007, 09:54 PM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
franks exactly right
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 11-11-2007, 09:25 AM   #5
Thanks, Frank... and Roofing God!
Do you think a saws-all is the way to get the hole in the metal roof?
Old 11-11-2007, 10:03 AM   #6
Yeah Use A Bi-metal Blade
Old 11-11-2007, 10:18 AM   #7
Rewards Points: 370
Do a search for "Triple Wall" and read what I said about Triple Wall on a previous post.
fireguy
fireguy is offline   Reply With Quote
Old 11-11-2007, 10:31 AM   #8
A "triple wall" fireguy search leads me back to this post... ???
Old 11-13-2007, 08:08 AM   #9
So I called a place that sells chimney pipe and he says double wall pipe is a better product than triple wall because it has insulation in it. And 2 inches of clearance to combustibles is what is needed. He also says they have boxes that go around the pipe through the attic... anybody have experience with this?
Old 11-13-2007, 09:57 AM   #10
yougot it covered,do it already
Old 11-13-2007, 12:13 PM   #11
The "Boxes" are called chimney housings or chimney surrounds.
Hart and Cooley recently stopped manufacturing their versio, which I have used for years.
Other alternatives are Majestic and Air Jet.
Majestic is already pre-assembled and the slight extra cost is worth the reduced hassle of assembling the panels together for the four sides.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-13-2007, 05:18 PM   #12
Thanks, guys!
Moisture-proofing chimney box wall penetration faithmyeyes Roofing/Siding 3 01-06-2007 12:23 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Another Leakey Chimney Jawx Building & Construction 10 10-21-2006 09:08 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
