Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-05-2011, 07:37 PM   #1
Chimney flashing rotted and siding question
Hi All,
Sorry if this is in the wrong forum.
What should my plan of attack be?
While we're here...you see how the corners of the siding stick out? How do I fix that? It does not want to push in...it just springs back. Were they sized wrong when the house was built 15 years ago (saw an old hornets nest in there already)? Only 2 corners shown are like that - the other 2 are fine.
Kdavid is offline   Reply With Quote
Old 10-06-2011, 07:56 AM   #2
I'm thinking of spraying the metal with rubber spray. I saw the informational for Flex Seal but it comes out to $40 for 2 cans.
Someone said truckbed spray is pretty much the same stuff and cheaper.
What do you guys think?
Old 10-06-2011, 08:55 AM   #3
Exterior Construction
Windows on Wash's Avatar
No, that is not proper.
What is the pitch on that cap like? Seems that it is pooling at the flue penetration.
Vinyl sided chimney on side of house - rotting OSB rfleege Roofing 55 11-23-2010 09:23 AM
Replacing Rotting Sheathing Behind Chimney. fredhead Building & Construction 4 11-19-2010 09:57 AM
replacing rotted siding on gable roof psd7.3 Carpentry 3 07-14-2010 02:27 PM
House trim has rotted my siding ovahimba Remodeling 5 01-22-2010 02:58 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
