Chimney/Flashing Leaking Into Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-22-2010, 01:09 PM   #1
pjm
Chimney/Flashing leaking into attic
A quick question about my chimney. I'm in Northern NJ and during the recent rainstorm we had I was in the attic and noticed water coming in through my chimney. I'm not sure if it's the flashing or if it's leaking right through the brick. The cement job towards the top of the chimney in the attic looks horrible to me as it looks like it was oozing out and just dried like that rather than scraping the excess away when it was done. My question is do I call a chimney guy or a roofing guy? Or do most do both? I'd like to get this looked at asap as I don't want it to get worse. Any advice/suggestions would be great.
Thanks in advance.
pjm is offline   Reply With Quote
Old 03-22-2010, 03:00 PM   #2
Commercial Roofing
AaronB's Avatar
I would call a roofer first because I have seen roofs leak more often that chimneys, but chimneys do leak.
Tough call
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
chimney leaking into attic kelley4180 Roofing/Siding 10 02-12-2010 10:55 AM
Attic leaking from Chimney? Fred123 Building & Construction 2 10-08-2009 06:00 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 10:29 AM
Leaking attic gable vents MoMo Roofing/Siding 2 04-02-2005 10:00 PM
