Chimney Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-29-2011, 12:14 AM   #1
chimney flashing
was rooffing and forgot to put the flashing on the chimney any way to fix this
billiesue1 is offline   Reply With Quote
Old 08-29-2011, 10:28 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
That seems like it would be easy to do.
Simple fix.,.,.,However sometimes its better to do it the hard way.
Remove all of the shingles around the chimney and install the flashing.
Just have to ask though.,.,Is this your own home ?.,.,or are you contracted to do this project?
Roofmaster417 is offline   Reply With Quote
Old 08-29-2011, 11:31 PM   #3
Rewards Points: 150
chimney flashing has to be bent and cut into the mortar joint of the chimney so water will not run down the chimney and behind the flashing thus getting into your wall and house.
guest is offline   Reply With Quote
Old 08-29-2011, 11:42 PM   #4
RFN-4A-LVN
I am pretty sure that they are talking about step flashing.,.,
Need help deciding giving this chimney flashing contractor a second chance tracyj Roofing/Siding 3 03-29-2011 10:56 AM
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 08:04 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Looking for Chimney Flashing Kit. Prefabricated? gante Roofing/Siding 11 02-27-2009 10:11 AM
