Is This Chimney Flashed Properly? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-17-2012, 09:10 PM   #1
Rewards Points: 29
Is this chimney flashed properly?
Had a roof put in, but I'm skeptical of the chimney flashing. I think the roofers cut the mortar out with a tile saw to install the flashing and then cemented it all back together with some kind of black goo. Is this done right? I can see gaps between the bricks...I was expecting some new mortar to be put in or at least something a little less sloppy.
lmorsino is offline   Reply With Quote
Old 06-17-2012, 10:53 PM   #2
Doing This Way Too Long
Rewards Points: 532
Can't tell much from that picture but it's probably np1 or something. It does look like your whole chimney is about due for some re-pointing though anyways.
OldNBroken is offline   Reply With Quote
Old 06-18-2012, 12:40 AM   #3
Registered User
Rewards Points: 526
Hard to see with the shadows.... does the lower cap flashing tuck under the next side one as in the bottom (second) picture here:
http://www.rumford.com/chimneys/flashing.html
Gary
Old 06-18-2012, 08:03 AM   #4
Rewards Points: 83
The only issue I could possibly see is where the front counter flashing (the ones that are embedded in your chimney) meets the side piece of counter flash. It "appears" to only be about an inch of coverage, and if the step flashing under that isn't tall enough, it may let water in. Again, can't see it well enough to tell for sure.
bcdemon is offline   Reply With Quote
Proper way to flash a stone chimney Arky217 Roofing/Siding 10 02-16-2015 10:23 AM
HWH vented up chimney--want chimney gone hummer4x4guy HVAC 14 01-31-2012 10:22 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Capping my chimney sbmfj General DIY Discussions 9 10-29-2011 10:45 AM
Chimney Firebox Leak Victim General DIY Discussions 1 10-26-2011 01:17 PM
