Chimney Covering Material ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-11-2009, 07:07 PM   #1
Curious Homeown
Chimney covering material ?
My chimney was recently rebuilt and the outer material is cement board. I can leave it as is or cover it with something. What would be a material you would use to do this?
Thank you
Curious Homeown is offline   Reply With Quote
Old 11-11-2009, 07:33 PM   #2
Your chimney is covered with cement board or cement siding. If it is a cement board as in an undrlayment, I would do a culture stone on the chimney. If it is a cement siding material then I would probably leave it.
RobQuillin is offline   Reply With Quote
Old 11-14-2009, 08:43 PM   #3
Curious Homeown
Stone sounds very nice! I did see some thin brick that looks pretty good also.
best material for shop wall covering? will52100 Building & Construction 7 02-20-2009 10:14 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
