Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-01-2010, 11:06 PM   #1
chimney
Just bought a house and during our inspection we noticed daylight around the chimney. The Home inspector said it doesnt appear to be leaking but I should have a roofer check it out. The roofer tells me the chimney is not leaking the day light Im seeing is a reflection from the "step flashing" does this sound right
kirkwithkac is offline   Reply With Quote
Old 08-01-2010, 11:12 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Yes. The light gets in where the metal overlaps the brick. Sometimes this area is caulked with clear caulk which still allows light in. If it's not leaking, it's hunky dory.
seeyou is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
