Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-25-2007, 08:20 AM   #1
CHanging roof pitch over poarch ?
Greetings--
Small older house, pier and beam that's no longer level.
Back porch and laundry room have flat roof-- that's of course now leaking. It currently has rolled roofing on it. Water tends to puddle at the joint, as the house "tilts" that direction slightly.
The main roof needs to be replaced. Its going to have to be torn off to the rafters and plywood decking added. Its currently 1 layer of wood shake shingles and two asphalt shingle layers.
QUESTION-- since the main roof is going down to the rafters, could I have additional rafters added to change the pitch of the flat portion to a "normal" roof ? Looking at it this seems a good replacement for the forever troublesome flat roof.
Comments ?
Piney is offline   Reply With Quote
Old 02-25-2007, 11:39 AM   #2
jproffer's Avatar
You could do it whether or not you were removing everything to the rafters.
jproffer is offline   Reply With Quote
Old 02-25-2007, 03:29 PM   #3
OK-- so is rebuilding the roof a perfered method-- or is covering the flat portions with a "rubber" type of membrane ?
The difference in the quotes is about $1k more for the job that suggested the membrane fix.
Old 02-25-2007, 05:36 PM   #4
jproffer's Avatar
Just depends on what you want. If you like having the roof flat, then it should have membrane roofing, yes. If you want it pitched, it's not a difficult job to add rafters and pitch it.
Also, you use the term "rebuilding". What I would personally do would be more like "adding to". There's no reason to remove any of the old roof unless it's in the way of adding the new. Even then, you only need to cut back enough to attach the new rafters to the ceiling joists or the front beam, whichever applies.
Old 03-06-2007, 10:13 PM   #5
The existing sloped roof needs replacing. Its at least 25 yrs old.
Some of the shingles have been damaged by wind, limbs ect. Its not leaking yet, but it will be soon. The roof vents' flashing all need to be replaced a well.
QUESTION-- Is there a perfered pitch ? The existing roof is a steep pitch until it goes flat.
One contractor planned on using 10 ft joists from the edge of the flat roof into the existing roof, resulting in whatever pitch that gives.
Old 03-06-2007, 11:55 PM   #6
Commercial Roofing
AaronB's Avatar
Preferred pitch? I prefer a 6/12 myself.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-07-2007, 12:49 AM   #7
jproffer's Avatar
Yea 6/12 is ok...but you can dance a jig on a 4/12...so when I'm gonna be..ya know...dancing uhh...jigs ......oh nevermind...go with the 6.
Old 03-08-2007, 01:43 PM   #8
another for the 6.has any thought been given for the space on the ends that will be open after you pitch the flat?
roofwiz74 is offline   Reply With Quote
Old 03-09-2007, 08:32 AM   #9
ummmmmm..... duct tape ??? Oh wait this should be in the HVAC forum *shrugs*
Thanks for the info folks !! Im getting a third proposal on this today-- I'll pass this contractor's info along for comments.
Old 03-09-2007, 06:25 PM   #10
jproffer's Avatar
I'll try this on this post, cause I don't have time to make an all out drawing right now. But he's talking about:
....................+............This area
+__________________________________
Side view. The line is your existing roof, the +'s are the new roof.
This should be framed in and sided.
Old 03-10-2007, 10:19 AM   #11
Commercial Roofing
AaronB's Avatar
Awesome CAD skills, jproffer.
Old 03-10-2007, 01:37 PM   #12
jproffer's Avatar
LOL...You should see my elevation drawings
Old 03-10-2007, 03:47 PM   #13
Any photos?
redline is offline   Reply With Quote
Old 03-12-2007, 03:45 PM   #14
I obtained another bid--this time w/o modifying the pitch of the roof.
This contrator said he would guarentee the workmanship for 5 yrs on the roof and 2 yrs on the flat portions.
His bid said they would use "x # squares of torch down" on the flat portions.
Can someone enlighten me as to exactly what this is ?
I'm still concerned that water which pools up at the joint between the sloped and flat portions will cause a leak.
Comments ?
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing 21 06-18-2007 09:58 AM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing 3 03-27-2007 01:16 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing 5 10-26-2006 11:31 AM
