Ceiling Leaking, Looks Like Some Roof Issues - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 01:28 PM   #1
Ceiling leaking, looks like some roof issues
Hello,
We bought this house 2 years ago, the area in the picture is part of an addition built about 25 years ago (probably the age of the roof as well). On the left half of the picture you can see the original house (75 years old).
The ceiling developed a wet spot and then dripped to the floor after 2 weeks of bad rains and wind. The wet ceiling is under the middle of the red circle, although I do not know exactly where the issue is on the roof. I don't know much about roofing, but it looks like the downspout circled in blue may be the cause of the issue over time?
I'd like to put off a new roof another year. Any suggestions on a possible solution to the issue? My initial thought was replacing some of the shingles that have been dripped on by that downspout, and then extending the downspout down to drain into the gutter at the front of the picture.
Thanks!
jwaller2 is offline   Reply With Quote
Old 04-20-2013, 01:35 PM   #2
Rewards Points: 14,278
Unless it's some sort of distortion in the picture it sure looks like that whole area is toast.
See how the whole area is wavy, sure looks like the sheathing may be rotted out under the shingles.
Old 04-20-2013, 01:44 PM   #3
That ripple is a straight line that runs the whole length of the lower roof section (on this side and the other). The angle of the roof slightly changes there, but it is uniform and perfectly straight, which leads me to believe it was built this way for some reason.
Old 04-20-2013, 04:36 PM   #4
Rewards Points: 252
I wonder if it is the wall flashing. That gutter essentially diverts all the water from that upper roof along that wall, so I bet it is overwhelming the flashing (or lack thereof). Try installing a piece of downspout onto the elbow you circled so it dumps the water into the lower gutter.
shazapple is offline   Reply With Quote
Old 04-20-2013, 05:10 PM   #5
Rewards Points: 6,652
First off, extend the downspout down to the gutter below. As for the leaking, I would also go with a flashing issue at the wall meeting the roof.
Old 04-20-2013, 05:40 PM   #6
Roofmaster
Rewards Points: 2,210
You need to open up the roof above where you are getting the drip inside, and trace the leak back to its source. Look for improper base (Step) flashing at the break in the roof. The deck looks wavy to the right so be careful you dont fall through. Can you see this area from below in the attic? If you can, shoot some pictures there and post them.
Old 04-20-2013, 06:09 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
have you been in the attic to look at that section of roof from inside? It does not look flat.
While that down spout might 'add' to the problem....I don't think it's your problem. But is worth correcting later.
Uneven ceiling drywall issues.... amadogon49 Drywall & Plaster 7 03-25-2013 02:35 PM
Ceiling issues in old home tbarker13 Drywall & Plaster 5 01-22-2012 08:53 PM
Leaking Roof dltigers3 Roofing/Siding 15 01-25-2010 08:25 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
