Cedar Shakes - Old And New - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-02-2013, 09:20 AM   #1
Cedar Shakes - Old and New
I am building a detached garage and am going to go with heavy cedar shakes to match the house. I need about 12 square, but I found a guy who has 8 square that he is selling very cheap. They are still in bundles, but have sat outside so that all the exposed areas are weathered.
If I mix and match these with new shakes, in a year or two, will they look as though they all weathered together?
Number 1 Red Cedar Heavy (40 bundles)
Ridge Cap (10 Bundles)
Here is a picture of what he has.
Thanks,
Matt
fullermatt is offline   Reply With Quote
Old 10-02-2013, 09:57 AM   #2
Rewards Points: 712
Thanks,
Matt
You're trying to match the house. I'd pass.
QUOTE: Ed the Roofer
You need to be concerned with the initial price only once… But you are going
to be concerned about Quality…for many years to come!!!
Old 10-02-2013, 10:17 AM   #3
[QUOTE=Fairview;1248681]You're trying to match the house. I'd pass.
Yes, I am trying to match the house but if I use new shakes it will not match, at least not day 1. I assume overtime the new shakes would weather similar to what is on the house.
BTW - the house has they same Heavy cedar shakes and is about 75 feet away from the detached garage I am building.
Old 10-02-2013, 10:47 AM   #4
Rewards Points: 712
The first thing I would want is the two different batches to be at a moisture equilibrium so I suppose you could spread all the wet outdoor less expensive out to dry or soak all the new until that happened.
Your choice but I have more pleasant ways to be frugal.
Old 10-02-2013, 10:51 AM   #5
kwikfishron's Avatar
Rewards Points: 186
They will blend at some point. I think a year or two is a bit optimistic though especially in areas that don't see much sun or weather.
kwikfishron is online now   Reply With Quote
Old 10-02-2013, 11:10 AM   #6
If it was just a few $$ I wouldn't bother, but he only wanted $400 for all of it.
Maybe I could use his on the side of the garage that will face away from the house. And use the new my side of the ridge.
Old 10-02-2013, 11:44 AM   #7
Rewards Points: 186
I'm seeing an awful lot of small and split shakes in those bundles. Looks like a collection of a roofers rejects. What pitch are the ridge caps, can you even use them?
Old 10-02-2013, 11:58 AM   #8
Good question about the ridge caps, and one which I do not know the answer. My roof will be 4/12.
Old 10-02-2013, 12:26 PM   #9
Rewards Points: 186
From what I can see in the picture those look more like an 8/12, definitely not a 4.
The Following User Says Thank You to kwikfishron For This Useful Post:
fullermatt (10-02-2013)
Old 10-04-2013, 12:11 AM   #10
Registered User
Rewards Points: 5,216
Those look like rejects, as said. http://miniatures.about.com/od/minia...inegarwood.htm
http://www.ehow.com/how_12082215_mak...weathered.html
Or just buy a store product.
Gary
Old 10-05-2013, 11:37 AM   #11
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks,
Matt
I'd buy them. They will match eventually. As noted above, make sure they're not mostly "skinnies", but it doesn't look like they are to me.
seeyou is offline   Reply With Quote
Old 10-05-2013, 09:47 PM   #12
Rewards Points: 2,238
Looks like "skinnies" to me.
rossfingal is offline   Reply With Quote
