Cause Of Water Stain On Vaulted Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-26-2014, 02:30 PM   #1
house4rentlv's Avatar
Cause of Water Stain on Vaulted Ceiling
We had 3 days of heavy rain in winter here in Vegas. This caused these water stains (see pics) on the vaulted ceiling. Had two contractors out to take a look and they both gave hefty roof repair quotes. I'm not sure if I really need to have that entire portion of the roof repaired/replaced since the house was built in 2005. Concrete tiles. It rained after that and I checked for wetness and the stains were dry. Any ideas on what would cause this? The contractors had no idea what the cause is.
Thanks.
Cause of Water Stain on Vaulted Ceiling-leak1.jpg   Cause of Water Stain on Vaulted Ceiling-leak2.jpg
house4rentlv is offline   Reply With Quote
Old 04-26-2014, 03:12 PM   #2
Rewards Points: 14,026
Sure looks like a roof leak to me.
No one on any web sites going to know how your roof was prepped or the quality of the job.
Old 04-26-2014, 03:14 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
The way the wind was blowing is the only thing I can think of. Do you know anybody that could recommend a good roofing contractor you can trust.
Robpo is offline   Reply With Quote
Old 04-26-2014, 03:33 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,652
Thanks.
Ayuh,.... Obviously, a Leak in yer Roof,....
Pictures of the Roof, might lead to some Ideas,....
Show the areas opposite, 'n above the stains on the ceilin',...
Pictures of the ceilin' ain't helpin',...
Wind blown rain can do some weird things,...
Bondo is online now   Reply With Quote
Old 04-26-2014, 03:38 PM   #5
Rob
Robpo's Avatar
Rewards Points: 826
Hey they posted pics on there first post you don't see that much.
Old 04-26-2014, 04:12 PM   #6
Both the contractors looked at the roof and they couldn't find anything. Wind blowing rain was what I was thinking cause it usually doesn't rain that heavily here in winter and the wind blows from the northwest instead of the south during monsoon season. Thanks, everyone. Any more thoughts, please let me know.
Sent from my SGH-M919 using Tapatalk
Old 04-26-2014, 06:38 PM   #7
Metal Roofing
Rewards Points: 600
If they cant see why its leaking then their only option is to remove the roofing on the section or sections above the stain and start from scratch. That being I&W, two layers of felt then reinstall the roof tiles.
We need pics.
This could just be a flashing issue but we are guessing without some pics of the roof.
AndyWRS is offline   Reply With Quote
Old 04-27-2014, 06:39 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,296
Post up some roof pictures.
Old 04-27-2014, 06:45 AM   #9
Rewards Points: 154
IF they couldn't figure out the problem then what exactly was it that they quoted you for?
eharri3 is offline   Reply With Quote
The Following User Says Thank You to eharri3 For This Useful Post:
oh'mike (04-27-2014)
Old 05-13-2014, 05:19 PM   #10
Chief Fungus Fighter
Open up the drywall...you will probably want to do it anyways to check for mold...and start doing a spray test on the roof until you find the section that causes a drip. Once you find it, repair.
MoldBuster is offline   Reply With Quote
Old 05-14-2014, 11:38 AM   #11
Low Slope Roofing
Rewards Points: 114
except water has a tendency to move to other places before it actually 'leaks'
1985gt is offline   Reply With Quote
Old 05-14-2014, 11:08 PM   #12
Yes but that gives you an easier starting point to start tracing it back to a generalized area, versus starting to randomly tear roof apart. In a dry area with a mostly dry structure, water infiltration will be reasonably easy to spot and trace once the lid is off. Being a Mold remediation company in a very wet area of the country, we deal with this type of thing all the time.
Old 05-16-2014, 01:15 PM   #13
Low Slope Roofing
Rewards Points: 114
I generally just measure off where the spot is and start looking up top from there. I guess I should start tearing ceilings out instead.
The Following User Says Thank You to 1985gt For This Useful Post:
roofermann (05-16-2014)
Old 05-16-2014, 02:47 PM   #14
Metal Roofing
Rewards Points: 600
That is how a non-roofer would probably approach a leak. Roofers also do not randomly tear apart roofs to look for a leak. As mentioned by 1985, we measure first and most of time we don't even need to do that to locate the problem.
The Following User Says Thank You to AndyWRS For This Useful Post:
Windows on Wash (05-16-2014)
Old 05-16-2014, 02:59 PM   #15
roofermann's Avatar
Rewards Points: 401
Did the weather go from cool (during the rain) to very hot? It could be a case of heavy condensation (common with vaulted ceilings). But like the others have said, most likely you have a leak.
roofermann is offline   Reply With Quote
Water stain on the ceiling shiyang100 Plumbing 8 02-11-2014 08:51 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Condensation on ceiling near water heater. EkS Plumbing 5 10-12-2010 10:48 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
