Caulking Gun Cleaning - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-20-2007, 10:12 AM   #1
Does anyone have any suggestions for the removal of roofing cement patch from my very expensive caulking gun?
miami vice 25 is offline   Reply With Quote
Old 05-20-2007, 10:42 AM   #2
jproffer's Avatar
Rewards Points: 706
gasoline or mineral spirits
Next time buy a cheapy from wallyworld and throw it away when your done.
Good luck
jproffer is offline   Reply With Quote
Old 05-20-2007, 08:27 PM   #3
Commercial Roofing
AaronB's Avatar
gojo, orange cleaner, bug and tar remover.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-21-2007, 05:03 AM   #4
and,
Goof Off, Acetone, Tolulene & MEK
Ed
P.S. Next time someone who is very sloppy with a caulk gun will be using it, spray it with WD-40 first.
Ed the Roofer is offline   Reply With Quote
Old 05-21-2007, 07:02 AM   #5
RippySkippy's Avatar
WD40 will work well on the tar based stuff....
RippySkippy is offline   Reply With Quote
Old 05-21-2007, 08:01 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Curious: How expensive can this caulking gun be?
- Build Well -
Old 05-21-2007, 08:48 AM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,336
It's all relative, I've seen caulking guns for $1.99 and all the way up to $13.99. $13.99 is very expensive, if you ask me.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-21-2007, 09:31 AM   #8
FWIW - To me: $13.99 for a decent no-drip caulking gun is average price.
- Build Well -
Old 05-21-2007, 10:00 AM   #9
Rewards Points: 1,088
Shocking. They have batter powered caulking guns nowadays.
handy man88 is offline   Reply With Quote
Old 05-21-2007, 01:00 PM   #10
I bougt a battery operated variable speed caulking gun back around 1988, for a job that I had to install several thousand feet of 1/4" bead caulk.
I didn't want my right forearm looking like a gorrillas compared to my left arm. I have also spent up to $ 30.00 to $ 40.00 for some real nice ones, but I quickly learned, they grow legs faster than the cheaper ones do.
Ed
Old 05-21-2007, 01:53 PM   #11
For a job like yours, I see the need. It's still a 2 hand operation though, as the battery powered device is obviously heavier.
Old 05-21-2007, 09:48 PM   #12
Hello,
We have used air powered caulk gun too. Unfortunatly they grow legs also. We use brake cleaner to clean caulking guns and nail guns.
Keith
roofboy is offline   Reply With Quote
Seal Caulking Tube? SnoBird General DIY Discussions 15 04-15-2011 01:23 PM
Cleaning siding firsthomegal Painting 6 06-01-2007 10:24 PM
Roof Cleaning before replacement.. RoofWarrior Roofing/Siding 3 05-15-2006 02:59 PM
caulking trim with silicone castleconcepts Painting 2 10-23-2005 11:16 PM
