Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-01-2011, 01:20 PM   #1
Caulk vs. embedding flashing in mortar
Everywhere I read it says to embed the cap flashing in the mortar. Our roofing guys want to just caulk it to the chimney, saying that putting grooves in the mortar will weaken it. I would think that, if done by someone who knows what they are doing the embedding way would be the best. Any thoughts?
bunburryist is offline   Reply With Quote
Old 10-01-2011, 01:26 PM   #2
Framing Contractor
You picked a bad roofer. Was he the cheapest?
sixeightten is offline   Reply With Quote
Old 10-01-2011, 01:39 PM   #3
Residential Roofer
Slyfox's Avatar
The only way cutting into the chimney would weaken it is if the cut were to deep or to close to the outside corners.
Caulking alone is not a proper method to install counter flashing's.
Face nailing the flashing and the use of caulking is acceptable.
The cutting into the brick method dumbafies the method so it is less likely to be a problem.
God Family Country Work Play
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
seeyou (10-01-2011)
Old 10-01-2011, 01:45 PM   #4
Exterior Construction
Windows on Wash's Avatar
+1
agreed on all accounts.
Old 10-02-2011, 12:39 PM   #5
"Nail-Bender"
Just to throw this out there.
Step-flashing fastened to the chimney -
Mortar cuts -
Counter-flashing, "pop riveted " to the step-flashing -
(Seen this)
Sealed with the appropriate sealant.
Seems to work!?
Mortar it? - depends on the condition of the brick - depends on the thickness of the mortar
joints - depends on the mortar... etc.
rossfingal
rossfingal is offline   Reply With Quote
Old 10-02-2011, 04:19 PM   #6
if your roofer told you that... find a new roofer
framingrailman is offline   Reply With Quote
Old 10-02-2011, 06:58 PM   #7
"Nail-Bender"
No - nobody told me that -
I've been up on roofs; and that's what I've seen - numerous times.
Just wondering if it "flies or dies"?
I don't know who roofed it, and no one told me.
OK?
rossfingal
Old 10-02-2011, 07:23 PM   #8
I was speaking to original post OK!
The Following User Says Thank You to framingrailman For This Useful Post:
rossfingal (10-02-2011)
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 33 01-03-2013 12:58 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
Can I Caulk this Flashing - Pics Attached bartgrometer Roofing 21 08-19-2011 09:56 AM
best caulk for flashing ElvisPresley Roofing 1 08-23-2009 08:06 PM
What roofing caulk is the best to seal flashing by chimney? twilightcall Roofing 1 05-13-2008 09:07 PM
