Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-04-2009, 02:34 PM   #1
Unhappy
Cathedral ceilings--ridge vent needed, or not?
OK, gang...we've had about 10 experienced roofing contractors give us quotes for replacing our 22 year old roof. We feel we have a good handle on "shingle quality" and proper installation and the like, but these "experts" seem about evenly divided on whether our cathedral ceilings do or do not need a ridge vent. We have NO attic. We have a two story great room with cedar ceilings (cedar is what you see inside the house when you look up) and even the master bedroom and master bath upstairs have vaulted cedar ceilings with no attic above them...just cedar ceiling, wood beams, with insulation on top and shingles on top of the insulation. 1/2 are telling us the roof was constructed incorrectly and that even a ceiling with no attic needs a ridge vent, and the other half say that's crazy talk and that the small "register" type vents under the eaves is quite adequate and that the contractors telling us we need the ridge vent are just trying to rip us off. The ridge vent proponents say the other people don't know what they're talking about, and that that insulation section needs a ridge vent so that it doesn't trap moisture and cause mold issues and doesn't attract carpenter ants (which are a constant battle for us). A roof is a huge purchase and we have one shot at doing it right the first time...so do we need a ridge vent installed, or not? We do have a shower in the upstairs master bath and there is no "ceiling" above the shower stall...the steam just rises into the air and is hopefully sucked in by the vent fan in the wall above designed to pull the moist air outside. Help?
Larenda is offline   Reply With Quote
Old 06-04-2009, 02:39 PM   #2
Say it Is not so!!!!
Planning on directly letting in or out environments????? Then, by all means, Vent it.
It has been my experience that this is NOT standard practice!
Here is sumpin' to read...........
http://www.fpl.fs.fed.us/documnts/pdf1999/tenwo99a.pdf
MALCO.New.York is offline   Reply With Quote
Old 06-04-2009, 09:30 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Were rafter vents installed in the cathedral ceiling before the insulation was installed?
I have several cathedral ceilings & all have/will have a ridge vents
Its pretty standard to do so
Keeping the roof/roof deck cool will extend the lifetime of the roof
Old 06-04-2009, 10:09 PM   #4
MJW
Ok, Dave, I'll let you have that one, haha.
Dave is right, and it is the code. Have the chutes installed and a ridge vent.
Pretty standard thinking. I can't believe anyone would want to seal up a cathedral roof. Turtle vents would do very little. I recommend ridge vent on everything.
MJW is offline   Reply With Quote
Old 06-04-2009, 10:21 PM   #5
Scuba_Dave's Avatar
That write-up is 10 years old
But it does point out:
Many asphalt shingle manufacturers do not currently warrant their shingles on unvented roofs.
There are good & bad ridge vents
Proper installation is also key
Also doesn't state where you are located
Up here in New England cooling isn't needed to an extreme
But proper ventialtion to avoid moisture is
And extending the shingle life
When I retrofitted soffits & a ridge vent into my front roof I also retrofitted rafter vents. When I pushed the final rafter vent into place there was a rush of cool air coming up
Even with proper venting & insulation my sunroom roof had ice dams this past winter. We had storm after storm & it faces South, so sun was melting snow & it was refreezing. No leaks - thank you ice & water shield
Old 06-04-2009, 10:32 PM   #6
Three different ways I agree with to vent and why: http://books.google.com/books?id=uiE...edral#PPA56,M1
Start on page 53, about preventing ice-dams, a good read. Be safe, G
GBR in WA is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
new roof, ridge vent was in est, but not installed... Zel1 Roofing 28 06-04-2009 10:20 PM
Ridge Vent > Gable Vent jelly Roofing 10 06-09-2008 09:30 AM
Ridge Vent on a Shed jokiddjr Roofing 5 03-14-2008 05:22 PM
low-slope roof and leaky ridge vent downers Roofing 15 02-22-2008 01:35 AM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 10:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
