cathedral ceiling sweats
We have a log home with a cathedral ceiling. The problem is it sweats when the temperatures are in the single digits and the sun pops out. Not only does it sweat but on the shed dormer, the pitch of the roof doesn't let the water drain, so it drips in the house into the loft, bedroom and bathroom. The ceiling is 2x6 tongue and groove, 3 1/2 " insulation panels with an R value of 18, 1 1/2" air space, plywood, felt then shingles. From what I gather we should have had a layer of felt put on between the 2x6 tongue and groove and the insulation. Well anyway, we are trying to solve this problem. From what I can find out, 1 way would be to remove the shingles, felt and plywood. Fill in the 1 1/2" air space with insulation, then install the plywood, felt and shingles so there would be no air space. Also, we have had a couple of contractors come out and they think that if we would leave the roof the way it is, install bubble wrap directly on the shingles, then put a metal roof on, this would also eliminate the problem and be less costly. Any thoughts on this as I would like to fix this once and not have to do it again!!!! Any help here would be greatly appreciated....thanks beth
