Cantilever Roof Sag - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-16-2012, 01:38 PM   #1
Cantilever Roof Sag
Hello,
I own a small ranch house with an attached garage. The exterior wall of the garage is inset 4ft from the exterior wall of the house. The roof over the garage cantilevers out 4ft and has the same roof line as the house. The cantilever part of the garage roof is sagging and i suspect the reason is the load bearing wall is inset 4ft from the heel of the roofing truss. The roof trusses on the house and the garage are all the same. To remove the sag from the garage roof can i simply jack it up level and add a vertical support directly above the wall between the top and bottom chords? If not what is an acceptable practice to repair this type of issue?
ljb8119 is offline   Reply With Quote
Old 06-16-2012, 07:02 PM   #2
DIY staff
Rewards Points: 7,174
That might just do the job---also --sistering in 2x4s along side the upper chords under the roof sheeting might be needed---post a picture or two---
Old 06-18-2012, 12:28 AM   #3
Registered User
Rewards Points: 526
I would post pictures before doing any work. Size/number of fasteners, size/thickness of plywood gussets at the new bearing point, etc.
Gary
Old 06-18-2012, 05:23 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 476
I agree, need pictures. If you do have trusses with 2X4s, a cripple above the plate trying lift all the load of the roof may just put a hump in the rafter part of the truss.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
