Can You Ridge Vents 3:12? 2x15lb Or 2x30lb - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-15-2011, 02:05 PM   #1
MB1
Can you ridge vents 3:12? 2x15lb or 2x30lb
I just had two different roofing companies bid my house for a new roof. One says they will not (and cannot anyways) put in ridge venting given a 3:12 roof. They say it is prone to leaking with wind driven rain. The other says they do it all the time and use the best system on the market called Shingle Vent 2. Which do you recommend?
Also, given that I am in San Jose, CA is it worthwhile going 2 x 30# felt or is 2 x 15# sufficient on a 30 year certainteed landmark shingle? (BTW, I am somewhat concerned about adding too much additional weight on my roof)
Thank you,
Marcum
MB1 is offline   Reply With Quote
Old 12-15-2011, 02:32 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Thank you,
Marcum
I would think ridge caps could leak, unless they have some product out there for shallow pitches.
What do you mean "2x" the felt? I would think 1 layer of 30lb.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 02:53 PM   #3
MB1
By 2x I meant two layers. I spoke with an inspector who said 2 layers have to be used. It can't be one layer of 30# in lieu of 2 layers of 15#. Is the two layers of 30# overkill and will it add much more weight than the 15#?
Old 12-15-2011, 03:00 PM   #4
Disabled wood vet
titanoman's Avatar
It's a Cali thing I guess. And it's no extra weight compared to the weight of the shingles themselves anyway.
Do you doubt the soundness of the structure for some reason?
Old 12-15-2011, 05:27 PM   #5
MB1
Well, I have 2x2 inch engineered trusses 24" on center. All the roofers who have walked it say it's solid and they do not feel deflection, but it currently has a 20 year 200 lb per square shingle and a thin single layer of craft type paper with thin tar as an underlayment (and 1/2 or 5/8" OSB). The Landmark is 265lb/sq, and 2 layers of #15 will add to what I have as well. Maybe the 15# vs 30# difference is nothing to worry about. I just don't want to overload it. From what I hear from the inspector, 30 year is very common for re-roofs of these.
Old 12-15-2011, 06:00 PM   #6
Disabled wood vet
titanoman's Avatar
2x2 trusses? Anyway, you should be fine.
Are they going over what's there or stripping the old roof?
Old 12-15-2011, 06:14 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
R905.2.7 Underlayment application. For roof slopes from two units vertical in 12 units horizontal (17-percent slope), up to four units vertical in 12 units horizontal (33-percent slope), underlayment shall be two layers applied in the following manner. Apply a 19-inch (483 mm) strip of underlayment felt parallel to and starting at the eaves, fastened sufficiently to hold in place. Starting at the eave, apply 36-inch-wide (914 mm) sheets of underlayment, overlapping successive sheets 19 inches (483 mm), and fastened sufficiently to hold in place. Distortions in the underlayment shall not interfere with the ability of the shingles to seal. For roof slopes of four units vertical in 12 units horizontal (33-percent slope) or greater, underlayment shall be one layer applied in the following manner. Underlayment shall be applied shingle fashion, parallel to and starting from the eave and lapped 2 inches (51 mm), fastened sufficiently to hold in place. Distortions in the underlayment shall not interfere with the ability of the shingles to seal. End laps shall be offset by 6 feet (1829 mm).
From the 2010 CRC.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
seeyou (12-17-2011)
Old 12-15-2011, 06:37 PM   #8
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
"but it currently has a 20 year 200 lb per square shingle and a thin single layer of craft type paper with thin tar as an underlayment (and 1/2 or 5/8" OSB). The Landmark is 265lb/sq, and 2 layers of #15 will add to what I have as well."
You make it sound like they aren't going to tear the exiting roof off.
I wouldn't even consider roofing over the existing.
Tear it off! And the Landmarks and felt won't add much weight.
I apologize in advance if I read this wrong.
tinner666 is offline   Reply With Quote
Old 12-15-2011, 06:41 PM   #9
Rewards Points: 13,300
This has to be a manufactured home, no real house would have 2 X 2's for trusses.
Old 12-15-2011, 06:41 PM   #10
Disabled wood vet
titanoman's Avatar
That's why I wrote post #6.
Old 12-15-2011, 06:48 PM   #11
MJW
With the way the roofing is described, I'm thinking manufactured home also.
FWIW, shinglevent 2 is not the the best on the market. I have pics of it failing within 15 years.
MJW is offline   Reply With Quote
Old 12-15-2011, 09:21 PM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
What is your favorite?
Old 12-15-2011, 10:04 PM   #13
Pro Slate Roofer
tinner666's Avatar
Yeah, I see I missed that one.
For Joecaption and MJW, he said it was a triple-wide in an earlier thread. This subject spans 2 - 3 threads.
This one mentions the home being a triple-wide.
Why Leaking Roof under Dormer / hole in OSB!!!
Weatherguard v.s. Ice & Water Shield, Priming first?
The Following User Says Thank You to tinner666 For This Useful Post:
MJW (12-16-2011)
Old 12-15-2011, 10:07 PM   #14
MB1
Thank you for all the comments and sorry for the confusion I created. Yes, this is a manufactured home about 2000 sq ft, triple wide. Pictures per my post here: Help!!! Why do I need to replace an 8 year old roof & how correct the problem?. I am definitely stripping off all the old material down to the sheething.
Will also use Winterguard in the dormer valleys, under the dormers, and around all critical areas. And, will skip the ridge venting although will likely add gable venting (unless someone thinks that isn't a good idea?)
Thank you,
Marcum
Old 12-16-2011, 08:43 AM   #15
MJW
Omni roll. No baffles to clog up, completely open NFA.
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 10:48 PM
do ridge vents really work ? Arky217 Building & Construction 2 08-18-2011 01:02 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 07:20 PM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 08:12 AM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 10:17 AM
